About NoEyeSquareGuy
- Birthday 04/13/1983
Location
Manchester
Vehicles
'01 Forester
NoEyeSquareGuy's Achievements
Member (2/11)
10
Odd... I can't seem to find one on rockatuo's website that's even nearly that cheap. The cheapest they offer is an AIRTEX piece for $62 and change, for an '01 Legacy. As far as extensions to reach the bolt, I use a 12" extension on a 12mm(I think it's 12mm, anyway, might be 13mm) deep socket. With a standard socket, a 12" AND 3" extension seem to work well.
I removed both from the "Y" of the Y-pipe after giving it a shot with worm drive clamps... they consistently needed to be tightened after a week or so, and I got fed up with it. I currently have both the pieces at the Y and those just after the cat clamped, and both still need to be removed. As previously stated, just don't go parking in long, dry grass with a stonking hot motor.
I'd have to disagree. My FWD Tercel with Blizzak WS-50s was far better in slush and deep snow snow than my wife's old Forester with then-new Dueler H/Ts. Crappy snow tires(Semperit and the like) may only be good for 15k miles, but a quality tire should last longer. By driving carefully and rotating often, the Blizzak WS-50s on my wife's pig of a Golf have nearly 35k miles on them, and should be more than adequate for the remainder of this coming winter. Sadly, yes. P245/75R16s and P265/75R16s are commonly available in no-name Chinese brands manufactured by TireCo for as little as $180, if you know where to shop. They're horrid. They're bad on dry roads and wet roads, and are so frightening on snow that I could not recount stories, or you would all flee screaming from the monitor. Typically they last 10k miles before they're corded in spots.
Most of us were born into it, and it's no big deal, as we've all watched idiots ditch their cars our whole lives. We also run great tires, or don't drive... bald tires up here means a sliding, ice, flaming death. I ran full-depth Bridgestone Dueler A/Ts on the Forester last winter and found it "inadequate." Snow tires aren't necessary, but it's hard to go back to all seasons after you've driven with the real thing.
General rule of thumb is that Subarus are like LEGOs... they're all built relatively similarly to each other, and are pretty simple to work on. Accessory belts are very simple to replace, timing belts and "while you're in there" jobs aren't nearly as simple, but are still a DIY job if you're handy. I'd suggest replacement of the water pump and timing belt tensioner, as well as a reseal on the oil pump in my "while you're in there" list.
