I have a 1991 Subaru Legacy with a 2.2L Turbo engine and a 5-speed manual transmission. I am having a problem with the cold idle speed. When I start the car with the engine cold, it idles rough (at about 1200 - 1500 rpm), it also seems to produce no power as even the slightest engaging of the clutch causes it to stall, until I rev the engine. After I rev up the engine the idle speed rises to between 3000 and 4000 RPMs and stays there, Once the engine temperature starts to rise the RPMs start dropping, when the engine is fully warmed up, it idles at about 600 rpm.
The check engine light is not on. I have taken it to a couple of mechanics they check the computer to see if it gives any errors but it does not, at this point they say they don't know what the problem is and can't fix it.
The problem first appeared after I had the clutch replaced in the car. I have taken it back to them several times to try and fix it but they have been unable. I had some other work done at a subaru dealership and asked them about it, but they were not able to find anything wrong either.
Do you have any suggestions on things to check to try and identify the source of the problem?
