slidewaysuby
Everything posted by slidewaysuby
anyone?
i need a clutch kit not a clutch cable, thanks though
so an xt6 clutch will work? what are the advantages of using that over a GL clutch?
Does anyone know where to get a clutch set for an ea82 4wd wagon for cheap? cheapest ive found is $170
im trying to help my buddy fix his 88 gl spfi. heres the problem, it will start after its been sitting for a few hrs and run perfect for about 5 mins, then it dies and has no spark. i checked the rotor and it is turning, the coil is getting power. has 2 cel 34,35 but its had those for years. has a new battery and we got the alt tested(the guy said it kinda bounced around but should be ok) anyone have any ideas? thanks, Dylan
Yes you can. Just swap the block and use your 1.8 intake and accessories on it. And run it off the 1.8 ecu. It’s an easy swap. You may need a different header depending on if the 2.2 is a single or dual port. It’s also possible to swap in a 2.5 phase1 without any rewiring. Search nasioc, a lot of people have done it on there.
Help, First Timer Timing Belt Replacement
slidewaysuby replied to Left_coast*9's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here ya go http://www.ultimatesubaru.org/forum/article.php?a=24 Dylan -
crack in turbo housing
slidewaysuby replied to slidewaysuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so i guess i will see if i can find a replacement. anywone have one they are willing to sell? Dylan -
my turbo on my ea82t wagon has a crack in the housing between the impeller and the wastegate valve i was wondering if i should replace the unit or will it be all right to use it? here are some pics of it http://pg.photos.yahoo.com/ph/sickxj/detail?.dir=2ade&.dnm=d874.jpg http://pg.photos.yahoo.com/ph/sickxj/detail?.dir=2ade&.dnm=d887.jpg thanks, Dylan
turbos use axles with a 25 spline doj and n/a use 23 spline doj. i've heard that turbos with a 3 speed auto use 23 spline, but not positive on that one Dylan
D/R swap question -- axle issues??
slidewaysuby replied to pwoens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well i learn something everyday, i thought all gl-10 were turbos. but on a side note he states it has rear discs, so i'm guessing it is a turbo. Dylan -
since your wagon is a gl-10, i assume its a turbo. if it is your gonna need to use the front axles out of the 86 (the n/a trannys use 23 spline shafts and the turbo trannys use 25 spline shafts) along with the rear diff since the ratios are differnt between the trannys. the rear axles wont need to be swaped. im doing the same swap into my 88 turbo wagon either this week or next. Dylan -
axles for d/r swap
My wagon is a turbo. so i have to change the rear diff cuz the one in there now is a 3.7 ratio and the dual range im switching in is a 3.9 ratio. also the 5spd turbo trannys use 25 spline shafts and d/r use 23 spline shafts with the exception of the rx fulltime d/r. sorry for the confusion Dylan
