Everything posted by slidewaysuby
hydraulic lifter ea81 heads on reg block
I did a search but didn't find anything that helps. Dylan
axles for d/r swap
bump..........
bump.......................
i have a hydraulic lifter ea81 with a cracked block so i moving all the parts over to another block but its not a hydraulic lifter block, what parts can i use, heads, pushrods, rocker assembly..... thanks Dylan
axles for d/r swap
bump...........
axles for d/r swap
thanks for the link, i searched but didnt use the right keywords.... but as far as axles go what do you recommend?
axles for d/r swap
im going to be swaping a d/r 5peed for my s/r 5speed push button in my 88 turbo wagon. what all is needed to do this swap? axles, d/r tranny, rear diff to match tranny and center trim pieces? as far as axles go i have 2 choices, axles for a 4wd turbo with an auto or axles for a n/a 5peed d/r. i hear the auto axles are stronger, is this true? thanks, Dylan
heater fan swich
in my 88 gl turbo wagon the fan swich stoped working on the high/4 setting. i tried another fan resister but that didnt help. i've searched but found nothing that helped thanks Dylan
speaker size
bump bump bump
speaker size
So the stock sizes are 4 in the front and 6 in the rear? Also what sizes would you recommend I get as replacements?
speaker size
Does anyone know the sizes of the stock speakers in a 88 gl wagon thanks alot
info on someone's project
i didnt see it close up, it was sitting at an intersection that i drove through
i saw a 87 or so wagon driving through gresham, Or yesterday. it had the back cut off to make it a bed and they moved the rear hatch up right behind the rear seat looked real good from what i could see. it was also lifted. i would like to see some pics if anyone has some.
87 rx good deal?
theres a 87 rx 2dr coupe forsale around here for 1300$ its in good condition except for a few things like the exaust needs some work and the check engine light is on and seatbelt doesnt retract and the clutch doesnt feel like it has to much life left. otherwise its in relly good shape 171000 miles power windows, door locks cd player old but works lsd rear end ea82 t 5 speed with center diff lock and dual range so my question is, is it worth $1300?
