About Gyoas759
- Birthday 05/07/1984
Contact Methods
AIM
Gyoas759
Location
Berks
Occupation
Self Employed!
Vehicles
2 83 GL 4x4s, 79 BRAT
Recent Profile Visitors
Gyoas759's Achievements
USMB is life! (4/11)
10
It's been about 2 years since I've seen an EA81 generation subaru at the Harrys in Hazleton. I had to make a last minute run up there today to get a few parts for a friend of mine. Theres a Red 1600 DL-5 Hatch and a GL-10 Wagon that were just put out within the last week. The hatch has about 188k and the engine is in the back of it. The tranny is still in it's place. FWD manual. has the single rectangular style headlight bezels and grill under the hood. Body is pretty rusty. The GL-10 has the sunroof and Digi-dash. Body again is pretty rough. This one looks like it's been sitting a while. Automatic 4x4 with the power options too. Thought I'd give the heads up. Hopefully I wont have to wait another 2 years to see some there.
The stuff seems great. It really has smoothed things out. So far I think my troubles are all "operator error" and no fault of the sea foam. I'll be putting some through my Toyota next.
Windshield -- what do I buy and from whom?
Gyoas759 replied to nwsunni's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd use something a little stronger than super glue. Try plastic emblem adhesive or JB Quick Weld in there and use the tape to hold it all tight for a few hours so it can set. The warmer the better. Should hold it down. I've also had success using indoor/outdoor caulk with such things. But then, it's not always the cleanest or prettiest job. -
I swapped in the new plugs this afternoon and it started right up. I warmed the engine a little and revved around 3k RPM until most of the smoke had subsided. The idle is better, the engine is quieter, but now I have a fairly loud tapping coming from the front left side of the engine. (Right side as you face it from the front of the car.) It sounds like a gnome is using a small jack-hammer in there somewhere. I still need to do a oil change following up the seafoam in the oil. Does this sound like the infamous tick of death? What should I do from here?
I just got back from AutoZone with my new plugs. Pulled the first plug with no problem. I'm putting the new one in (With anti-sieze) and it just gets tighter and tighter as I turn. about 1/3 of the way in and I'm putting a lot of effort into tightening this plug down. It feels way harder than I think it should be on an aluminum engine. I backed it out and compared the old and new ones. They're the same thread and everything. I'm trying to put NGK BPR6EY-11 plugs into an EA82. Any advice?
That had been a thought but it seems to be getting gas just fine. I even put a little gas down the carb just to be sure. Still wouldn't fire. I'm going to put new plugs in today and see if that cures it.
I got caught up in the enthusiasm of Seafoam. Never tried it before. Today, my room mate and I drove to a dirt trail (To spare my neighbors the trouble) Did as I've heard before. Added 1/3 to the gas, 1/3 to the oil and 1/3 down the carb. (This is an 83 GL wagon) I added it slowly through the carb so it wouldn't stall until there was only a little left, then poured enough in to stall the engine. I waited ten minutes and got ready for a smoke cloud. But it never started. It cranks over just fine. I drained the battery, walked home and got my toyota. Used the jumper cables and tried cranking again. A few times it feels like it wants to fire but doesn't quite start. Mostly it just cranks. Seems to be getting gas just fine. Even put a little down the carb just to be sure. Gave it an hour to just sit. Still wont fire. Towed it home with the toyota and it's safe in the backyard now. Any idea what gives? Anyone had any similar experience with seafoam?
Thanks. I finally found the spot where I originally saw this mod. http://www.subarubrat.com/easyshock.htm That's the direction I was hoping to go. I guess this extends the bottom and not the top. Looks like it's about a 2 inch extension in those pictures? Would 4 be pushing it?
Yes. EA81 rears. SJR is the plan. "installer must provide new rear shocks 4" longer then stock" The set up I had seen cut the tops off an old pair, slid them over the top of another set and bolted them together. Just trying to get some decent visuals.
I'm planning on ordering a 4 inch lift kit this week. I know I saw a way to cut a pair of old shocks to slide over and bolt to an existing pair to get the necessary lift from them but I just did about 5 searches and can't find the process. Anyone know of the thread I'm talking about or have some good info and pics on how to do this? I assume add 4 inches of length to the shock for a 4 inch lift? Is there an easier way or a good source for a shock that will fit the 4 inch lift? Particularly if it's something that could be found in the JY.
Finally getting this stuff taken care of. I drove the car 6 miles today to get it inspected and the vibration is gone. Does this confirm the bad axle theory?
How do you remove a transmission?
Gyoas759 replied to Greenley's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/showthread.php?t=49952 Here you go. This is for installing a 5 speed, so if you're just replacing yours just reverse the removal part. -
Welcome to the board! Depending what year your brat is, the motor can fit. The 1982-87 Brats are known as EA81 cars from the engines they carry. Most of the cars in 1985 were known as EA82 with a slightly different engine. It changed to timing belts and had a little more horsepower. Do you happen to know what type of car the engine came from? A wagon, 4 door coupe, RX, XT, hatch or Brat? If it came from a hatch or a brat, it's an exact fit. If it came from any of the others it can fit with some light modification. I drive a 1983 Wagon which originally came with an EA81, that now runs an EA82 under the hood. There's not a lot of performance gain, but if it's all you've got, it will work. What year is your Brat? Do some searches on the board, you can probably find some more detailed info on swapping engines.
Yup. It's there. And in this case, it says not to go over 50. I figure if 50 is safe on a pathfinder, 55 (Which is about as fast as my Sube ever goes) is still well within the safety realm since a Subaru is a much lighter beast. The Subaru these are destined for is primarily a local and trail riding car. This winter it sat around until a snowstorm would come through. Then we'd go out and have a little fun. I wouldn't choose these tires if I used my subaru for road trips, but I think it's the most cost effective option for my circumstances. Yet to be seen though. We'll see what happens when I start driving them.
83 subaru wagon exhaust on 83 subaru brat?
Gyoas759 replied to Clayton's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It should be the same fit. The tail pipe would be the only thing I'd question. If the wagon is longer than the brat, you might need to cut a few inches off. I bolted up a newer EA82 exhaust on my wagon today and it's about the same. You should have no trouble with the 83s. The mounts and everything are probably in the same place.
