Dave643
Everything posted by Dave643
Hey Guys - back again - tested the battery with a multi meter - 12.6 volts - hit the key same click - hooked the battery charger - no go, same click - seems like the click is coming from the brand new starter - could the new starter be bad? maybe a relay issue? any advise would be appreciated, tired of the Subie sitting around...
I just checked all the cables everything is nice and tight - after the drive home starts effortlessly - sure seems like a charging / drain issue but the battery is 6 months old and checked fine at auto zone - GreaseMonkey03 - can't tell because of course it starts now that I'm home - i'm leaning in the direction of throwing a new battery and cables in....Might pick up a multi meter to check for a drain
I have a curious starting issue with my 2002 Outback with 230,000 on the clock and new to me,. Did not start one day after work - turned the key, only got a click Got a push and bump started it and drove on home the next morning same thing - just a click - hooked up the battery charger for a boost and it started just fine Battery new, tested good - alternator tested good - all cables good, no loose connections Any ideas before I pull the starter to have it tested??? Thanks,
Greetings - Long time member looking for buying advice - I have to replace my old friend Rubie the Subie - Love this old car and was heading for 300,000 miles (made it to 287,000) but a run in with a deer on the way to work this week changed my plans... So - Looking for a replacment, something in the 10 year old range - anything out there i should avoid??? What's going to be the most bang for my buck? Thanks!
my daily driver is a '95 Brighton with 247,000 on it and it just keeps rolling along - I have done my best with U Pull and Pay parts to de-brightonize it - I added the Tech, factory CD player, power-outlet, A pillar speakers - all the factory wiring is in place, just pull the parts and plug them in! Great little car!
Hey Guys - long time since I've posted here - My '95 Legacy Brighton has developed a oil leak - a quick look and I found a puddle of oil on the passenger's side of the motor, on the top more towards the back....Won't have time to investigate fully until the weekend - any ideas? 2.2 with 247,000 on the clock....
Did you use a Subaru PCV valve? Off brands do not work well.
Great survivor.... http://bringatrailer.com/2010/01/18/40k-mile-survivor-1985-subaru-gl-3-door/
http://bringatrailer.com/2009/10/19/corner-case-survivor-1984-subaru-brat/ Check it out....Hope this hasn't been posted
Well I got her started. It was just an old and very nasty battery. Some water and baking soda on the cables and a fresh battery was all it took. It would not idle until I noticed the air intake was disconnected. She needs some TLC but she drove the 60 miles home with no problem. BTW, my brother in law is a slob...It may take a week to clean the inside :-\
