wes200x
Contact Methods
Website URL
http://
Location
san diego
Interests
working on subies
Occupation
student
Vehicles
86 GL-10 87 RX
wes200x's Achievements
Advanced Member (3/11)
12
Not sure if this is the correct place to put this but if anyone has a Xt6 they are parting out I am looing for the crossmember out of a manual trans. Doing a STI conversion and this is one of the last parts I need. Thanks
Great build I was wondering what brand and part number are the spherical bearings you went with Looking to make a set of my own for an RX build. And by chance do you have the part number for the 2015 sti pillow bushing thanks. Great work agian.
? on using NA block for turbo application
wes200x replied to wes200x's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here are a couple ansers to some of the replies I have read. My block does not have the cover or the castings in the case to run the 3rd vent it is completely different than the turbo block. Also you can not split a ea82 block without first removing the wrist pins. The base of the pistons will hit the main journals in the case. -
yes I was talking about the 3rd pcv vent. I was worried cause I know turbo motors usually produce a little more blowby and not only do those vents go to the pcv but they also vent crank case pressure. I just thought there might be an issue with 2 much positive crankcase pressure without the 3rd vent. thanks for the responce -
Okay I am on spring break so it is time to put a motor together. I took 3 motors apart and the best block is a carbureted block that I had before the car went turbo. My question is will I have any ill effects of putting turbo pistons in a NA block. I noticed the NA block does not have the 3rd blow by passage on the back of the motor. I know people have run the entire short block with NA pistons, So I just wondered if anyone has thought about this or do some NA blocks have the 3rd blowby passage. Thanks for all feedback
Does anyone know EA82 head bolt part #'s
Yes I understand that the bolt are not torque to yeild, but some of the bolts had pretty bad pitting and I would think that it would affect the strength of the bolt. Also I have looked at a buch of websites and now one list the head bolts. And a lot of the sites will show the part if you have the part number. -
EA-82 Rear wheel bearing questions (yet again)
wes200x replied to ZRX Doug's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well the number on one of my bearings is NTN 4T-CR1-0683. But there is no number on the race. The race intsself is one piece for both bearings that I'm sure was specially made for subaru. So I don't think you will be able to get it from your local bearing shop. Hope this helps -
I got this rx a while back for 500 bucks. So far I have installed inter cooler fuel pressure regulator BOV spider intake matching xt computer turbo timer zero sport air diverter gauages steering wheel not yet installed emanage ultimate 5 lug swap Also if steveman09 sees this I have some ?'s on install. I wanted to see what engine code he is using in emanage software.
I don't know if this helps but my rx was having a similar problem. just before it went on to boost it had a surge shutter then cleared up. It almost felt like the clutch slipped then grabbed again. My car also had a crappy idle. It idled really low or at about 1100. Well it turned out to be a leaking injector. Yesterday I replaced all 4 and now it is perfect. Idles is smooth as silk and no more shutter before boost.
I was down at my local pick a part in san diego california and there was a pretty nice xt6 manual AWD. all I want is the sway bars. Everything else was there including 4 good motion wheels with center caps. 5 lug conversion etc. Also it had a good dash trim. I go down once a week so if anyone needs something let me know. Also in a couple weeks it is 50% off day at that yard. so parts could be cheap.
Are ebay timing belts any good?
wes200x replied to glfarnes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would say go with the goodyear as long as they are the gatorback and not their cheaper model. Just don't use the Autozone brand duralast I think is the name. worthless. Gatorback belts are great. -
Momo steering wheel hub 7302 on Gen3 (EA82) Car?
wes200x replied to Marck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just purchased a personal steering hub off ebay for 29 bucks. It comes with the pins to turn the turn signal off. Fits great and fits nardi or personal steering wheels which I must say are very nice and look just like a momo. You can buy an adapter to go from personal to momo bolt pattern. the part #4702 or old code #5910. very nice part. Hope this helps I love mine
