2
Everything posted by The Dude Abides
IAC service on EA82
The Dude Abides replied to paulpicard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The thing is, that the ps resevour is in the way. I know there are ways around this but it needs taken off anyways. The o ring is bad somewhere. Does anyone know what size o ring it takes on the bottom or side, or whever the darn thing leakes. But yes this and the cts sensor need cleaned up as well. Ben -
Lift kit for Loyale Wanted.
The Dude Abides replied to tedbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try Here. http://www.sjrlift.com/index.php?option=com_frontpage&Itemid=1 -
IAC service on EA82
I really need to do this as well. clean my iac and make sure my hoses arent clogged. -
Check out my subaru replacement
The Dude Abides replied to Bigbusa's topic in Non Soob Cars and Bikes Discussion
Thats a great van. Those are the ones i wanted. Proven reliable drive train. AWD to boot. But my wife (grrrrr her choice) didnt like it because the passenger legroom up front and she thought it was ugly. I told her its much more then that and a van like that would last us a long time. Plus with a full size frame they were stouter then the other ones and they had a towing capasity. Well needless to say we pickedo a 05 caravan. Its been a decent rig but we dont have xtra room when we go on trips. The tranny is funny and has been funny in these cars since they were 1st introduced. Though the astro/safari is still classified as a minivan they are more macho then the front wheel drive cheepies. Congrats on the find. -
I hope that was an attempt to be sarcastic.
rump roast. Im working on it.
I forgot to ask what kind of car do you have. Do you have a single range or dual range 4wd. For me with the single range, when its engaged its planted. I cant spin the tires at all, it feels like its kinda kicked down a peg on power.
lol im looking for a specific meaning.
How did you modify that to fit on your GL
I havent done it on the fly but yes you can.
To to-fix list of my Loyale
The Dude Abides replied to z4x0r's topic in Old Gen.: 80's GL/DL/XT/Loyales...
133 THOUSAND MILES. Its dead, its so dead. Just send it to the Junkyard. Im kidding these engines are pretty stout and can get up to 300k with good maintenance. I have 209000 on mine right now. Youve got to find out where the coolant is going. Either its going in the engine out the tailpipe or its going out of the engine onto the ground. Do you smell coolant burning. Check the fins on your radiator, they have a tendency to clog or if to old become missing. Also check your heat output for possible clogged heatercore. Did you change out the thermastat as well. These cars like the oem subaru t-stats only. When you replaced the waterpump did you check out the hoses attached to it and see they were cracked. Do you have white exhaust smoke. Can you smell the coolant out of the tailpipe. -
For me, i just went on some gravel roads. Put it in 4wd when i felt the rear kick out a little i knew it was working. I wouldnt recoment tieing it up to a tree. If you have the single range it is vacume actuated. Listen closely when you engage it you should hear a whisp of air as the diaphram is actuated also.
Obviously you want to talk care of the mechanical aspect first. Since we are coming up on cold weather i would worry about anything but engine and brakes until next spring. Your engine situation worrys me. How many miles are on your car. You need to check your cooling system out. Make sure its not clogged. But if your losing coolant you need to figure out why and where. You have the possibility of a leaky water pump, leaky hoses or worse head gasket leak. These dont go so often on these cars unless there turbos. But they do happen. Not to hard to do some say but its up to you. Check engine light comes on, you can run the codes to find out whats tripping it. Coolant temp sensor or idle air control valve have been known to make these engines run at high rpms when they are dirty or non functioning. Brakes for these cars are cheep but somewhat a pain in the butt to do. Requires screwing the caliper piston back into place instead of pushing it. If you have the means and you can score them you might want to get a set of rear disc brakes. Dont require much for the conversion but you stop (OH) so much better. Belts are easy, just take them off and show the parts guy at the counter. You dont have transmission fluid if you have a manual, you have gear lube. Check and find out where its running out of oil. Get your vehicle to run long enough to crawl underneath it and check for these leakes. Do some diggin on here and find guides and wrightups on what to look for and what to do. Timeing belts are another good thing. Make sure your 4wd is working. Lots of parts and help to be had on here. Welcome aboard and nice looking ride. -
Stop showing me how much fun your having, i want to have that kinda fun.
Do you currently have a auto or manual. That will answer alot of questions.
Where to buy 185/80/13 tires?
The Dude Abides replied to eulogious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just did alittle checking with a few sights. Tires plus is showing a firestone fr360 for size 185-80-13 and TireRack is showing Kumhos for that size as well. The only other thing you can do is get pug wheels with allows you to get 14 or 15inch tires. OR redrill some 6lug wheels but they dont always look good for street use. -
Honestly the only place ive seen tires this size are at walmart. Just dont get the douglas tires. Spring alittle more for the goodyears. -
If your just swaping engines, you get an adaptor plate and keep your original transmission (single range) from your dl car. If your swaping engine and tranny then it gets a bit more complicated. I believe you half to change front axels to match the ones in your new tranny. I think your asking if you can switch in a awd tranny but still keep your single range transfer case. If thats what your asking then we have a problem. The 4wd unit in these cars is 1 piece. You either have single range, or dual range, awd or just 2wd. If the tranny is still good in your wagon i would just get the adaptor plate and call it good. Though if you had alittle xtra bucks i would get the dual range setup. Superior with the low range option.
Yet ANOTHER problem! Clutch? Bearing or cable?
The Dude Abides replied to Fox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Funny i have the same sound, comes from the driverside. Interested to know where this is going. -
Im in, oh wait. Well in spirt
PS3 for Subaru
The Dude Abides replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All ive got to give is a ps3 brent. So unless your up for a trade. -
PS3 for Subaru
He sent me the pictures, you guys were right. It was the one with the blue wheels, and beat up front and rear. No way im not that despirate. -
Uhh guys i dont want to pee in anyones pool. It has more clerance and a solid front axel. And you can put on 31inch tires right from the getgo. If it has a 5 speed its perfect. The aftermarket is huge on those. Inline 6 was one of the best engines ever made. If i was looking for a cheep wheeler thats where i would go. I love my suby, but the benefits of wheeling a stock jeep cherokee vs a stock subaru are kinda not even close. IM just saying, but if i didnt love my subaru i wouldnt still own it.
I dont have alot of money but i did pick up a 80gig ps3 about 6 months back. Now first of i love this thing, the graphics are awsome but i hardly play it. I mean like 1 or 2 times a month. I ended up emailing that guy about his GL with his run on sentence. Anyways he said he would trade straight up. Now im waiting to see pictures of this vehicle but i was curious of anyone thought this was either a good or bad idea. It would be nice to have a 2nd car. And its the GL with 5 speed dual range. The price of playstations is down to 300 bucks so basically its a fair trade. http://desmoines.craigslist.org/cto/1409878723.html
