Location
Missouri
Vehicles
'00 RSTi, '04 Foz, '80 BRAT, '79 GL Wagon
cobcob's Achievements
Subaru Nut (7/11)
12
This differs depending on what seller the exhaust is bought through. It's a crapshoot in that regard. Mine fit on just fine. There's no interference and the header traces a nice clean line around the filter. There's about 1/8" of the filter that hangs inside the curve of the header and there's clearance on all sides.
Gotcha, sorry I missed your comment. Must have been posted while I was answering the other post! Chances are that there is a donut gasket at the back end of your stock cat pipe. When I installed my catback I removed the donut gasket and cut the small stub of pipe off the flange. I then used a flat flange & gasket for attaching my exhaust adapter which steps up to the 3" catback. Just be aware of that incase you want to go back to your stock exhaust.
What to get on my License plate?
cobcob replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pwned Seems fitting for a sleeper STi swapped wagon! -
Welcome!! http://www.ultimatesubaru.org/forum/showthread.php?t=50768 Timing belt procedure for the EA82
True, you unfortunately can't use this as a hard and fast measure of if the HG's in the motor are good or not. If the HG's were replaced but the tech didn't clean the overflow bottle then you're still going to see that residue in there. It's a good thing to check but it's easier to determine HG issues by looking at the driver's side of the engine from underneath the car. The HG leak tends to evidence itself by dark marks at the joint of the head to the block. The coolant typically drips onto the exhaust manifold and evaporates while the engine is running which is why you won't typically see puddles of coolant from this type of leak.
