Mtnrider9800
Location
Kaysville, UT
Vehicles
I Love My Subaru
Mtnrider9800's Achievements
Member (2/11)
10
Hello, I am looking at a 1997 Outlook 2.5i that needs the motor replaced. I am looking for a project to do with my 2 boys. I want to put in a turbo charged engine from a WRX. I have not seen information about this. is it possible? is there more to it than dropping in the engine and connecting the tranny? is there electrical systems that need to be changed? If there are other posts that answer this question, please guide me to them. Thanks, Scott
It is an Outback manual tranny with about 170,000 miles on it (I replaced the speedo head and lost some mileage in the process). The mechanic is not sure if the compression problem is in the valves/heads or the rings. I would love to do it for less than a new engine. I would love to stay with a 2.5 engine, I like the little more power. Thanks for the suggestions.
I have been having a rough idle and the CEL was on with codes P0302 & p0304. I took it to a mechanic and he found that I had put in the "worst" spark plugs when I traded them out and that the spark was tracking to the nearest ground through the wires. So that made it run a little better, but he kept getting weird readings, more research done and cylinder 4 is showing 75 PSI and the other 3 are showing 150 PSI. The head-gaskets were changed 4/5 years ago and nothing is leaking. The mechanic recommended a new engine to fix the compression problem. What I need is a recommendation on a supplier of good quality low mileage engines and What engine can I put in the '99? I do NOT want another EJ25. Thanks in advance for any and all advice.
It is a 99 OBW with about 124000 miles on it. The code is the #4 cylinder misfire (p0304, i think). I have changed the plugs and wires. Still get the same code. I replaced the fuel filter, no change. The thing that I notice is that the idle speed is 250 rpm and rough at lights. After the CEL is cleared I can be driving and it will turn on again at start up or at speed, no change in performance or acceleration. Any suggestions will help.
My speedo on a 1999 Outback started working inconsistently. I had the speed sensor changed while other work was being done. It still did not work all of the time, but the cruise control did work. I purchased a speedo head online and installed it last night. I went for a little drive to test and it did not work at all, not even a flutter while driving. Any suggestions or tips would be appreciated.
