NocturneVoyager
Everything posted by NocturneVoyager
These are some NICE sketches! Well done!
Flex Seal to repair trim
NocturneVoyager replied to superpoo93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think with some painter's tape and newspaper, you could probably just spray this on smooth and let sit to cure. I've actually thought about doing it myself! -
Wiper adapter
NocturneVoyager replied to NocturneVoyager's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Will the 22" wiper blades still work with that adapter, or would I go down to a smaller size? ('86 XT GL single-wiper windshield) I also wonder if the Trico B98999-146 Wiper Adapter will work as well. -
Wiper adapter
I found one once that had a two-hole adapter, but the spacing was all wrong, so thinking may just have to stick with OEM blades, which I can get, or perhaps try the Aamco ones. -
Wiper adapter
Thanks for the info, Numbchux. I may check Aanco to see if they have one, but it is nice to know that you can get them from Subaru - and we have a dealer here in town too. Nice guys! The older one always enjoys yakking about the cool XT's and their unique appearance. -
Reminds me of when I was able to buy a replacement trim bezel for my 86 XT GL. It was at Subaru of Plano, TX. Stoked!
One of the members a while back was making wiper adapters for people who have the odd 2-hole bayonet wiper arms, so other wipers could be used (example: mine is an 86 XT GL). Does anyone have the details on this? Thanks again!
I'm just trying to think of a way of HOW to get it re-bent back into position, or if that is just a lost cause. I'm hoping I can save it if possible so I can have my seats re-upholstered.
Pillar trim fly away
One of the guys I work with seems to think he might know where to find another trim piece if this one is beyond hope (gonna try and be gentle to bend it back in), so we'll see how this goes. At least the windshield doesn't leak without it, so I'm happy there. Just little trim pieces here and there getting brittle after almost 30 years and starting to crumble, but this one was a bit of a surprise. I'll keep everyone posted on the progress. -
On my 86 XT GL, someone rear-ended me, and my driver's side seat went back, and now won't go all the way up properly. I'm assuming something just got bent bad and needs bending back into shape because the seat goes back and forth - just not all the way upright.
I don't know if this has already been checked or not, but I had a problem with my 86 XT GL overheating and could not figure it out. Finally took it to the shop and they told me that the radiator was congested/constricted about 90%, so had to be swapped out - could not be flushed out. Not sure if you already checked down that road or not.
NocturneVoyager replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is my little soobie - an 86 XT GL This is the passenger's side pillar that the trim flew off of. This is the recovered trim piece. I only hope I can get it bent back into shape, or if someone has a spare, that would be awesome too! I just don't know how these attached, but from the looks of the surroundings, it was pretty much adhesived into place with something good and stong. Thanks! -
I will take pics and post them here tomorrow when it's light out. It's an 86 XT GL Coupe. :-) -
My poor Soobie is falling apart, it seems. I was driving to work today and I noticed out of the corner of my eye, this flash of black flying off my car. I circled around to find it was the trim piece that covers the pillar between the windshield and door! Wow.......that had never happened before, but by the time I circled around to get it, someone had run over it, so it had this bend in it. I did pick it up and take it with, but not sure how to get it back on (assuming I can carefully get it molded back into shape (not TOO terribly bent). Judging by the fittings, it looks like it was attached from inside somehow, so not quite sure how this can be re-attached, or if I should just find some thick rubber washers, position it in place and epoxy it in or something. I know parts like this are hard to come by, so any thoughts or recommendations are always welcome. Thanks!
DIY fix for door trim?
Sorry....yes, it is an 86 XT GL. Thanks! -
The rubbery trim that goes from the top of the door to the window on my Soob is cracking and breaking off. I had thought about trimming it on the part going to the door, and then using Flex Seal and tape off a strip to cover where the part that was trimmed off was. Not sure if this trim is still available. Thoughts?
Show off your roos Mileage!
NocturneVoyager replied to beataru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
126,127.5 on my '86 XT GL, and still going! Someday I so need to fix this up, but so much cosmetic work inside that needs TLC......... -
Dash bulb replacement
I may end up waiting until I can replace the dash pad itself, because it'll probably disintegrate if I try to move it to get behind the instrument cluster. I appreciate the information though! -
My speedometer is OK until about 45, but if I go faster, the needle doesn't go back down until I slow down to about 35, and then it drops. Would this be the speedometer itself, the cable, or something else?
radio support bracket
NocturneVoyager replied to soopsoop's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I remember the guy at the stereo shop giving me the stink eye because apparently my stereo bracket was missing - not sure how it's held up in the back right now, so I'm guessing I'm gonna have to hit the parts shop and get another bracket to fit back there so the stereo isn't loose. -
Re-covering beat to heck dash
I'll check those out. Thanks guys! Oh.......and I found out the reason the heater blower stopped working is because the relay for it went kaput and stopped working, so off to the shop it goes on the 1st to get that brought back to life so I can drive it even when it's colder! -
My poor '86 XT has been without a good style since I bought her years ago, and one of the biggest problems is the dash top - you know....that piece of the dash you see through the windshield. Poor thing has had a piece of fabric over her since the day I bought her, and looking undeneath, it has nasty splits in a couple of different places. I'm not sure if this is something I can have re-covered, replaced, or if I should just put an aftermarket dash cover on it. I have a new trim bezel to go on the front, but wanted to have the rest of it nice first. Opinions? Recommendations? She needs some life breathed back into her. Mechanical-wise, she's in good shape, although I need to find out why the heater blower stopped working, so I can drive it in the winter time again. Thanks all!
For rare parts, I found an accent piece that I've heard is pretty rare. I'm going to someday get the top of my dash done (it has nasty sun splits in it), and when I do, I actually have a brand new replacement bezel piece for the front (where it wraps around the vents, radio, instruments) for my 86 XT. Gonna wait until it's ready, and then get the new beauty face put on that baby! Only 125K miles, but dang..........still going STRONG!
