Mendodave
Contact Methods
Website URL
http://
Location
Little River, California
Interests
Motorcycles and Subarus
Occupation
Computers
Ezboard Name
Mendodave
Mendodave's Achievements
Advanced Member (3/11)
11
Yeah, and that IS cleaned up a bit. there were more before! d
right rear, looking at the engine, correct. Left and right concerning the engine is when looking at it. that little T is either blue or red or some color, i can't remember d
just like working in my yard, i know what you mean. just relax, that carb was rock solid since I put it on there. you will see the problem in the morning. Hard to find stuff when its dark, i know. black hoses are hard to see. there is a little T-fitting near the right rear, small red i think plastic thing. That might be it. david
you've got a leak back there if you sprayed cleaner and the idle went up. put a little screw in each of the small hoses you unplugged from the aircleaner, those can cause a stumble if you're running without the aircleaner. It sounds like either a cracked hose or an unplugged one. do you have enough light to do this right? dave
Don't fret over it, the idle air screw is pretty tough to find. It sounds like you got the right one, left side, about an inch or two out from the carb d
did you spray carb cleaner around the the carb, while running? little spurts, each quadrant. right front, squirt, listen, left front, squirt, listen, etc. be patient. you will track it down. Did you perhaps turn the air adjust screw and not the idle screw? The idle screw is on the left side, the air adjust is low, in the center. I had that air adjust screw almost fall out, halfway between Mendo and Phoenix. would have been a bad spot...some luser adjusted it wrong, you can't get good help these days....
Hey D! that vacuum diagram won't help much, it is all different in there. I am sure it is a vacuum leak, though. That carb was pretty reliable for me. It might help to gently lift the aircleaner up, you need to loosen the right front 10mm nut, and remove the left rear one. The only butterfly nut you need to take off on the top is the middle one. Look at the extra aircleaner first, you can see the various vacuum pipes on that. It might be the one to the right, rear, under the aircleaner. You said you wanted to learn mechancial stuff, you are well on the way! just ask the board, we'll get you through this. Mendo
Dalton, the Reno Kid, I call him, has just picked it up. You boyos (and girlos) up in that area take care of him, I gave him the 'Keep your Subaru Alive' book, but he needs guidance. have fun with that thing, Dalton! I sure did! See you at the rallies! Mendo
hey y'all doesn't look like I can make it...:-\ three weeks in a row of working, if i do this run up to HR, it will be 24 hours of driving and one day of mud bogging with everyone...then back to another three weeks in a row of work...this is solid work, weekends too. I know, whine whine... I think I want to stay home and relax this weekend...but, we will see what Friday brings. Hey Junkie, could you bring my mug back if I don't show? I get over to Sac fairly often...hoist a few for me, too. Thanks! Mendodave
Hey y'all I can't really pre-register, but I will try my damnedest to get there. Gotta pick up my mug, ya know! the old PKmobile is blowing a bit of smoke after a down hill engine compression session, I think the new muffler burnt a valve. It happened after that...I had the guy put a constricter on it, and it is much better. Of course, it could be the 199k miles, which, with the big wheels, is really more. I have a spare engine, with two busted studs, one intake manifold, one exhaust. You know, the normal ones. I want to crack 200k before putting it in, so I will probably drive the old engine up there. what the heck. gotta get those studs welded with bolts and see if they come out that way. otherwise, I will see you all late Friday night David ('84 Subi wagon, lifted, 15 pug wheels, lsd, etc)
reeeeeeelly? mine has been tweaked a bit too. that '81 tranny helped a lot, and a big exhaust all the way back from the y pipe. growl! lot more snap to the throttle. i need a weber next, but i am trying not to throw any more money at it. you'll be going up earlier than friday afternoon? usually when I bomb up like that I head up Hwy 101 to Crescent City, then Hwy 199 to Grants Pass, and I-5 drone the rest of the way. It's 12 hours that way. Leave at 3pm, get there at 3am, i could stay at the sisters friday night, but i bet there will be people up at the rally. dave
hey gang well sheeeeit. i have to save all my vacation time for one big splurge. dad is paying airfare to spain for any of us kids that want to bicycle with him on the camino de santiago, a 800km pilgrimage. i can't let the old fart go by himself! so, nvzeno and junkie, i will be there, but probably blast up after work on Friday, and back on Sunday afternoon. flog the old 'roo, which is running pretty fantastic right now. i have some wagon wheels (two sets), a hood, two front fenders, and other bits if someone wants them. i will stay at the show, instead of my sisters, make sure you all don't have too much fun. now that the steering rack is replaced and the lsd installed, the mud pit will see the pkmobile! dave
Hi Tony, Remember me? Mendodave....I ordered a roof rack from you, like you made for Brian. My rack was welded with a bad welding rod, so all the welds are breaking. If you could, I'd like to either ship it back, and have the welds redone, or maybe have you make another and have it powder coated, then I could drive up there and return these bits, and pay for the difference. I seem to remember you saying you had a way to get the roof racks painted. Thanks! welcome back! Dave
