markjw last won the day on March 13 2016
markjw had the most liked content!
About markjw
- Birthday 12/19/1967
Gender
Male
Location
Lacey,Wash.
Interests
I'm into anything with a engine. I build Storage Sheds as a past time. I'm really good at it too.
Occupation
Tugboats, Columbia R.
Ezboard Name
Bif Malibu
Biography
Living in Western Washington most of my life. Love it here.Subaru Heaven
Vehicles
Lotsa Junk right now.
Recent Profile Visitors
markjw's Achievements
Certified Subaru Nut (8/11)
38
Loyale 2.7 Turbo started following markjw
88 GL wipers do not work at times
markjw replied to 88subaruglowner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a similar problem, I ran a separate ground wire from the body of the wiper motor to the firewall. Fixed! -
Engine Reseal/Clutch Job Parts List
markjw replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't mess with the rear main seal unless it's leaking. Also, the past several 80's/90's era subaru engines I've resealed, I've made it a point to replace valve stem seals. I was getting away without doing it for alot of yrs, the engines are just getting too old and if it's not done, you'll risk ending up with a oil burner after all your hard work. -
loyale d/r problem, stuck in neutral
markjw replied to toyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
An easy way to check, set your hand brake hard, put your tranny in first gear and let the clutch out. If you get that far without the car stalling, get out and see which axle nut is spinning. That'd be the bad hub. -
I had a hard time following what exactly is going on with your car but make certain that the splines in one of your front hubs isn't stripped out allowing a front axle to turn without delivering power. -
ECU still thinks its an automatic (5MT swap)
markjw replied to Ibreakstuff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In the end, I disconnected the electrical connections to the IACV. Aside from having to depress the accelerator a little on cold start up, it's running near perfect now. The idle is sweet (after warm-up) but of course it's throwing a CEL code. I can live with it until I sort thru why following the recommended advice on the board here isn't working out too well for me -
head gasket replacement, questions as I go...
markjw replied to andrsn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've never worried too much about the red seal. If it's handy and in good condition, I'll reinstall it. If it's not, I slap the flywheel on without it. Seems to not be too critical. I use red or blue loctite on the flywheel bolts. -
If the pointer is pointing at the middle hash mark, then the hole in the face of the driver side cam gear should be at the 12 o'clock position when you install the driver side belt. Then rotate the engine over until the hole in the face of the driver side cam is at the 6 o'clock position and the pointer is again at the middle hash mark. Now move to the passenger side cam, position it at the 12 o'clock position and install that belt. When you drop in the distributor, the rotor usually points somewhere towards the back edge of the brake master cylinder for #1 dizzy pole.
Don't mess with the "idle set screw" on the throttle body. That's not what it is. And adjusting it from its factor setting will only make your problems worse. Are you sure you've set up the timing belts correctly?
A few questions regarding my recent GL-10 purchase
markjw replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've also seen the weird casting holes in the head. Nice ride, btw. -
I had that surging at cruising speed once, took forever to track it down. In the end, the TPS wasn't getting good ground into the ecu. I simply ran a new ground wire from the TPS to its pin at the ecu, it ran perfect after that. Sorry, I can't remember which one of the four TPS wires is the ground. Easy to determine, thou. -
So, I've followed some of the advice of this thread and managed to get the idle somewhat under control. You can leave the fat wires connected, but you have to cut the inhibitor switch wire on the ecu harness. At least then the ecu functions normally. Previously, I left the fat wires connected with the inhibitor switch wire still connected to the ecu, that was causing wild idle fluctuations. At this point I think the idle isn't perfect like it should be, but the car is drivable and throwing no codes. If anyone has any ideas for me, please share. Thanks! -
One thing is for certain, at least on my car, jumpering the two fat wires together at the shifter console is a Bad Idea. I've had to remove the jumper after startup or the ecu freaks out when I start driving. -
This is what I wayou s looking for!!! Thank you so much, I'll give this a try in the AM and post back with confirmation. Now that I take a second look at the wiring diagram.. I do see that pins 32, 1, 46, and 13 are designated for AT. I feel dumb that I did not see these before. I'm wondering if ever sorted out your erratic idle after you did the swap. I'm having the same dilemma. Also, did you ever look into pins 1,13 and 46. -
Replaced a toyota P/S line, now no power steering?
markjw replied to idosubaru's topic in Non Soob Cars and Bikes Discussion
I'd look harder at the bleeding/air in the line. Nothing else makes much sense. I had a Outback that just wouldn't burp or bleed or whatever after installing a new pump. I gave up on it,after a couple days of driving, it fixed itself. I think there was a big air bubble in the rack that finally worked itself out.
