Joenasnj
Location
Bordentown
Vehicles
I Love My Subaru
Joenasnj's Achievements
Advanced Member (3/11)
10
The car keeps loosing water/antifreeze and I have no idea where it goes. Does not smoke just starts over heating. Put a new rad in it and still does it. I know when my 2.5 did the same thing it was the head gaskets I'm assuming it the same for the 2.2. If so can the heads be removed in the car or do I have to remove the whole motor? thanks Joe
OK, Let's Nail Down This PURGE SOLENOID Thing
Joenasnj replied to Tank's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where can i get a 33ohm 5 watt resistor at? looked at radioshack and no luck. -
i have a 1997 Subaru Legacy gt 2.5 sedan. I have a factory am/FM cass. with CD player. When the car is off the radio plays fine but when the car is running it get interference in FM mode. i thought the radio was bad so i changed it with a nother factory radio with the same problem. The radion was fine untill the past week. Any clues on the problem? thanks Joe
I have a 1997 legacy gt 2.5 sedan AWD automatic trans. The car runs(did a whole head rebuild and reseal) and drives great except when i put in reverse. If i push the gas lightly it moves fine, but when i hit the gas hard i get a skipping grinding noise i think fro the front diff. If I hold the brakes the noise is bad and get no motion pressure on the brakes. My question is is the front diff bad and can it be fixed without doing the whole trans or is the whole trans bad? How are the JDM trans listed on E-bay? Thanks Joe
I have a factory keyless entry system. The problem is i can lock all doors and unlock the drivers door. It will not open all the other doors. The manual says to hold down unlock button to open all doors. I have tried this and it doesn't work. Is it the remote itself or the door lock module? thanks Joe
