CNY_Dave
5
Everything posted by CNY_Dave
If fuel filter is in the engine bay and has 3 lines, the return line to tank could be routed to a jerry can and the engine run. I have to drain down mine this week prior to it going to the scrapyard (my '03 LL bean H6 with exhaust gas in the coolant). Scrap prices really suck right now! $80/ton for a car (4 cents/lb!)
I have the bigger HF transmission jack- I had to have the rear jacked up with jack stands with a 2x10 underneath each jack stand, and the front was on good jack stands with I think 2 pieces of 2x10 under each one. I have a decent floor jack and needed to put a 4x4 on it to raise the car high enough. The jack has a height of about 8.5 inches, pretty high http://www.harborfreight.com/800-lb-low-lift-transmission-jack-69685.html
Assuming auto, in general you can use a 2001-2003 (in addition to '04) with perhaps changing a solenoid and valve in the tail section. When I did a swap of an '04 LL bean 4EAT into an '03 LL bean, the interchange they used wrongly stated an '04 would swap right in to an '03. Hollander actually updated their interchange manual based on my info!
My H6 has never overheated but has been pushing gas into the coolant since may. Sometimes the symptoms are hidden. A slow gas leak will not blow hoses as the system can't exceed the cap pressure. A fast leak can build pressure faster than the cap can release it. If a hose blows at or below cap pressure, it was a worn-out hose.
