CNY_Dave
5
Everything posted by CNY_Dave
The lower hose will be cold until the thermostat opens, then it gets hot- so could be t-stat. Heater core connected and not blocked or blocked off? If coolant can not flow through these lines the t-stat might never open. Try getting the front end high and burping it. Radiator fans come on?
- 31 replies
- Overheating
- Radiator
(and 2 more)
Tagged with:
Stuck in AWD
CNY_Dave replied to ln41's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
98, will the manual TCU code reading method work? BTW, it could be a broken wire to/in the trans, or a fried driver on the TCU.- 11 replies
- Torque Bind
- Duty C Solenoid
(and 2 more)
Tagged with:
Always good to have a pdf of it to steer folks to- easier to print than a thread!
- 2 replies
- Center Differential
- Viscous Coupler
(and 1 more)
Tagged with:
Much better off swapping the transfer solenoid, valve, and valve plate from your old trans than trying to deal with it electronically. The signal is a lot different than just the inverted version of the older signal- the electronic inversion box kinda worked, enough to get me through the winter, but didn't really work well.
You could reach into the trans where the pan goes and pull the wire off the plug that goes to the solenoid and feed it +12V and see if it clicks. The plates will typically stick rather than slide when there's trouble so it's probably not plate material/backer, esp if not magnetic. I would bet on a grooved clutch drum, or maybe normal wear. FWD fuse is a good test, when you get it rolling again.
Depends on what you mean by 'shavings'- tiny silver glistening flecks, or metal pieces? Not sure if folks have seen silver in the trans fluid from the transfer clutch plates, I could see a grooved clutch basket leaving some. How sure are you the vibration is torque bind- does it disappear when you put in the FWD fuse? If it is the transfer clutch/basket and the rest of the trans works fine I'd say just pull the tail section and just fix what's broke.
