CNY_Dave
5
Everything posted by CNY_Dave
Seal-puller is cheap and useful, some folks drill a small hole and thread in a sheet-metal or wood screw and pull with pliers. Yes, just put it at the same depth, usually seals like that go in flush with the end of the hole they are seating into. If that one is set in a bit, just set it in the same amount. Once you get it out you will probably see a surface it seats against.
2006 will not fit. 2001-2004 H6 non-vdc will fit, using a 2004 requires a part be changed inside the tail section.
- 8 replies
- Transmission
- Differntial
(and 1 more)
Tagged with:
My 03 LL bean used to be great on glare ice, wet ice, you name it. Now it's a bit of a ghostwalker, even with good snows. The steering has that 'eager to move off center' feeling familiar from previous cars I've had when I've loaded the heck out of the rear. I think my springs must be sagging after 250,000 miles.
snow plow
CNY_Dave replied to RED DEVIL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Of course the way the winter is going who knows if you'll get to test it! -
I have had 2 in mine from NAPA for many miles, only downside was one didn't come with a dust shield around the inner stub side (I swapped from my old), and another I had to bring back and swap because the roll pin holes wouldn't line up in either of the 2 possible orientations (and usually only one of those 2 work, I know).
