CNY_Dave
5
Everything posted by CNY_Dave
Below 30mph or so it will look at the front speed vs back to help make torque transfer decisions. In 1 it does apply a little more torque to the rear by default. What happens when you gas it a bit before removing your foot from the brake? What happens if you go to '1' then back to 'D' then take off? I could see sticky plates or a grooved clutch basket causing a short delay that maybe going into '1' 'fixes' (plates do what they should before power applied) If it's all working properly locking the clutches doesn't really buy anything, with the added problem that going down slick hills the rear will slide out as front braking force gets transferred to the rear wheels. External filter- you definitely want to use the subaru.
snow plow
CNY_Dave replied to RED DEVIL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Plowbaru! http://www.subaruoutback.org/forums/61-general-discussions/11887-snow-plow-subaru.html -
I'd say chains on all 4, only the front if you really onlky want to do 2, and any damage would only be from the chains actually hitting body panels. If it's slick enough for chains, my guess is only having 2 on can not generate enough torque against the other 2 to damage the AWD, an auto probably more resistant to damage in that exact circumstance..
Doesn't really need to be H6 specific, I *think*, as long as you use a legacy (not outback) trans. legacies use 4.11, outback 4cyls 4.44, H6's 4.11 01-03 all swap across each other (VDC for VDC, non-VDC for non-VDC) as far as I know, they did according to the interchange manuals when I swapped mine.
I've thought about it, just too lazy. I did bother to alter the wiper switch so they don't automatically start to wipe when hitting the squirter though- that's a windshield saver! And it saves the view when the fluid is out of frozen, sometimnes doing nothing is better than just smearing what's there.
There must be one here or on subaruoutback.org. It's not too difficult, lots of stuff to disconnect, engine needs to be supported, trans needs the car pretty high to fit out from under (really high if you use a trans jack!), don't lift by the trans pan, make sure converter slides back from the engine, make sure the converter STAYS all the way back, for a donor trans make sure converter is all the way back or is seated, with engine and trans mated converter should not be touching the flexplate.
