CNY_Dave
5
Everything posted by CNY_Dave
Its fairly cheap from the dealer. I would use just hose before using copper. Anticipate similar rust on the one that goes under the drivers side head (but above the frame). Check your oil pan for rust-through leaks.
- 8 replies
- coolant linerust
- replacement
(and 3 more)
Tagged with:
Could just be one of the trans cooler lines leaking somewhere that looks like through the bell housing. Could be a seal between the trans and the front diff filling the diff with ATF- check the diff level with the diff dipstick. Could of course be the seal around the torque converter- that would require trans removal. Transmissions can be found www.car-part.com You probably should stick to a trans from a 6 cyl. Must be a non-VDC trans. Yoiu can use up to 2003 trans with no mods, up to a 2004 if you sweap a small part over in the tailshaft housing (extension housing)
This it? http://cobratransmission.com/output-shaft-bushing-r4ax-el-4eat-1301065-1?zenid=66b05e870376f4a32f8287bc531c7ea0 Or is it this one? http://cobratransmission.com/external-housing-bushing-r4ax-el-4eat-1301068-1?zenid=66b05e870376f4a32f8287bc531c7ea0 which is unavailable... These guys may have the second one. http://www.autorxpro.com/store/product.php?productid=22575
That bushing holds the outer part of the driveshaft yoke and is THE rear support for the output shaft. So, it's important. The nose of the yoke might be worn too, but it's steel and the bushing is aluminum plus other stuff. I bet you can find the bushing with some googling. If not, junkyard extension housing with one that's not wiped...
Mmmm, clutch basket could be badly grooved, clutches could be worn out, clutch basket may have fallen off the shaft, solenoid valve stuck, the spool valve it controls could be stuck or loose, the O-ring that connects from the transd side to extension case side could be bad or missing, the pipe that sends the fluid to the clutch pack could be loose and leaking, on my 03 theres a small filter screen behind the valve, if you have one somewhere (I think your valve is in the tail section? mine is on the trans proper) it could be plugged.
All the clutch pack parts are replaceable. Come to think of it, if the solenoid is open or shorted, and it does not have AWD, since the solenoid is activated to release pressure (before 2004) it will probably need something other than just the solenoid, unless the solenoid is stuck 'open' (which is a possibility). There are several simple and fairly cheap problems it could be in addition to the solenoid or wiring.
