CNY_Dave
5
Everything posted by CNY_Dave
I would be skeptical its wheel bearings. Have all the other front end components been checked?
The duty C code can only be thrown by the circuit breaking, or shorting to ground, or improbably shorting to +12V. It could be the wiring from the TCU to the trans harness, or the trans harness, or the solenoid itself. Suggest checking to see if shorted to ground or at the trans harness connection at the top of the bellhousing.
GAH! How long can you nurse a Gen2 front ball joint? Picked up a new clunk recently, I have a front ball joint with about 1/4 inch side-side play when jacked by the frame, but I have a few hundred miles to do this weekend... do these pop quick, or can I be gentle and postpone the work until the next weekend? I have to do 60 miles this week, then a few hundred, then another 120 call it next week if I postpone. It would be a real effort to repair before the trip. Dave
I just wanted to post up that having a supercharger under the hood is possible, and not so farfetched! I was a total auto noob once, I don't mock simple not-knowing and especially not when someone is asking so they will learn... I recall this one guy, had a 60-something chevy, engine said 'turbo-jet' on it, so he was sure there was a turbo in the block... but he didn't want to know if there was or wasn't!
I think if you tighten the lug nuts carefully enough, that is get one just seated, then the next in the star pattern, then the next, and let the lugs center the wheel you can center it with no centering ring. You can also get shaking if there is corrosion on the rim where it faces the rotor, or on the rotor face. YMMV.
On my '03 which has 6 CDs stuck in the changer, there was one day where I had to pull the fuse, the changer kept trying to load or eject with the key off. Try moving shifter around with key turned to 'start'. Our forester had a binding shift cable that kept it from moving forwards just enough it would not engage the interlock.
