CNY_Dave
5
Everything posted by CNY_Dave
Recently had the fob battery get weak, or at least the fretting corrosion on the bat finally did it in (worked if you moved the bat a bit). Anyway, after replacing the battery the fob works but- works fine to lock often will not unlock until I hit the lock button 3-5 times, get the lock chirp, then unlock works. Thoughts?
I'll add my tale of H6's not liking to be run for 20 seconds then parked then started the next day... Had to move my car to get the wife's forester in the garage yesterday, was only about 30 degrees. Moved it 30 feet, ran it 20 seconds or so, was interested to see what the next day's start would be like. Contemplated taking around the block just in case. Should have! Well, the car had so little compression the next day I was not even sure it was turning over! Holy crap! It was not flooded as far as I can tell, just seemingly had zilch for compression. But for opening the car door I would have sworn the starter was spinning but the engine not turning over. Took quite a bit of cranking before it even seemed like it was going to kick. Cranking with it floored did bupkis. Started and ran normally after many attempts. Oh, and add me to the P0420 club, too, got the code a few times before this fun...
Are you sure the trans code is for duty c failure? The trans can only detect if the current is too high (shorted) or too low (open). Either case, the AWD would be locked on. Engine idling TCU connected has a very small amount of front-rear 'lockup'. TCU disconnected it should be max lockup. TCU disconnected, all 4 wheels in the air, both rears spun (or one spun and one held still) yes, one front should spin.
tHE CONVERTER WHEN SEATED (oops) should look like it is ready to scrape the back of the bellhousing. If you put the engine and trans together the converter must NOT be touching the flexplate when the bell housing and engine are fully mated. If you mate the engine and trans and the converter is touching the flexplate and you pull them together with the bolts... bye bye pump!
The duty c on the trans with the tailsection removed? It bolts to a metal plate with no gaskets between it and the plate or between the plate and the trans. The duty c itself has a rubber o-ring type seal, 2 bolts, pull the solenoid, there's the o-ring on the solenoid. But, mind you, when it is working properly, and venting some pressure to give other than 50/50 lockup (which never actually happens) the fluid dump path is actually through the solenoid, so I would expect it to always be spraying. Pull it and check the o-ring... you can also disconnect the wire (if it's not an '04) and it should hold pressure.
Oil Pan Leak
CNY_Dave replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Couold the pan have a pinhole or tiny crack near the plug? I noticed on mine the threads are made from a piece spotwelded to the pan. -
I had an axle from Napa where the pin holes would not line up, rotationally. One way was obviously a no-go, the other way rotating the axle 180 was closer but the hole was still occluded. I returned the axle, next one fit no sweat. To clarify, old pujn, new pin fit into the stub fine and into the joint fine, the splines/holes just had a rotational tolerance stackup or such...
