CNY_Dave
5
Everything posted by CNY_Dave
There is typically one or more sense wires, maybe a sense-ground wire, and the shield wire. The shield wire will have its own pin (or maybe more than one) all the way back to the ECU. Any good mechanical conductive connection to the shield and another wire/piece of shield will work. It is OK if there is a short gap in the shielding.
I have not done the VTD swap, got laid off late January, started working a temp contracting engineering job in April, start my permanent job this coming Monday, and I sent my rear VTD housing to someone that had cracked theirs. It is guaranteed to work, the gears don't need ay input from the TCU, known issue is that the trans will throw a code because of a difference in the signal from the rear speed sensor. The VTD uses a small metal 'gear' to send the signal, the MPT uses the outside of the clutch basket, which has more 'teeth'. If the MPT front sensor has the same number of teeth on its 'sensor gear' as the rear on the MPT, I've wondered if you could just wire the front sensor to the front ands rear inputs. A daring soul could try getting a new rear sensor gear machined, or even boring a hole in the case and moving the rear VSS so it can getr a signal from the same-dimaeter fewer-plates sits-further-back VTD clutch basket. Some have said it may be possible to squelch the code with one of the ecu/tcu reader/programmer tools, like FreeSSM.
I think I recall an emissions equip problem that would fill the charcoal cansiter with gas when filling/driving, which would then cause a too-rich condition. Sound familiar to anyone?
- 7 replies
- hesitation
- outback sport
(and 1 more)
Tagged with:
And as far as I can tell, dumping to the resistor is optional. There is some discussion out there that you will kill the TCU if that connection isn't wired to *something* but it's just a solenoid driver, and also as soon as the AT Temnp light starts flashing the TCU stops trying to drive the solenoid. You do need to shut the key off to get it back to normal mode after disconnecting the solenoid. In fact, you could probably use a momentary-off switch in the circuit, push the button long enough to set the fault, then release and it probably won't try to use the solenoid again (unless it defaults to 'front wheel drive')..
It's pretty simple, a switch disconnects the trans from the TCU, and switches the TCU to a resistor to keep the TCU from thinkiing something has gone wrong. I temporarily had to use a switch ('04 trans AWD solenoid uses the opposite signal from all before that, and of course I put an '04 trans in my '03), and I can say if your AWD is working properly, there will be very little gain to adding the switch. And yes, locked on a hard surface would be bad, bad, bad. One real negative of locking it is down a slick hill, the rear wheels will slide because of the braking forces transmitted to them via the front wheels. Found that out going down a slick snowy hill...
Repeated failure has to be one or more of: - cheap bearings - bearings that need to be greased before use - damaged by the install process (sloppy press usage, weight on bearing before torquing, etc) - hub worn/damaged - knuckle out-of-round BTW bearings from subaru look like they have almost no grease, and cheap stuff at that- I installed a front as-is from subaru many miles ago, no problems.
- 6 replies
- outback
- wheel bearing
(and 1 more)
Tagged with:
