CNY_Dave
5
Everything posted by CNY_Dave
There was a time period where subaru spec'd the wrong lug nut torque, wonder if they missed the update ? I do not believe that aluminum wheels need to be retorqued, IF the hub is clean, both rotor surfaces are clean, the wheel is clean, and the nuts are properly torqued. I might amend that philosophy if a credible loosening mechanism can be described, but torque mine with an electric impact wrench, I go a certain amount of turning after snug, and my nasty LL bean alloys have always stayed tight. I think I recall reading here or elsewhere the phenomena GG mentions about the bad rotor, man, when you can't even trust a rotor...
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
They suck at torquing lug nuts, that's all there is to it. If they are left too loose, you can actually have all 5 shear at once and have the wheel sail right off. When they are not tight enough, they flex every time the wheel rotates.
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
If the problem is intermittent it could be the wiring between the transmission control unit and where the wires go into the transmission have been damaged, or a connector is not fully plugged in. What was the service they did?
- 3 replies
- AT OIL TEMP
- control unit transmission
- (and 1 more)
My snap ring was bent- I straightened it. http://www.ultimatesubaru.org/forum/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=7296 here's a close-up of where the clip snaps into the converter: http://www.ultimatesubaru.org/forum/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=7294
If I still lived in CT (Berlin) I'd be dropping by to gawk! Dave
- 10 replies
The solenoid switchover can eb checked by putting in the FWD fuse then checking the voltage on the solenoid circuit/pin at the TCU or elswhere. FWD fuse with +12V to the solenoid = 'old style', 0V to lock-up, +12V to disengage FWD fuse with 0V to the solenoid = 'new style', 12V to lock-up, 0V to disengage
