CNY_Dave
5
Everything posted by CNY_Dave
3.90 or 4.11
CNY_Dave replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I know for gen2 outback autos got 4.44, legacy autos got 4.11. H6 outbacks got the 4.11. Does cars101 have gearing info? -
I pulled the battery and the windshield washer reservoir and was able to get it in/out by applying just a wee bit of upwards force on the engine. There is a bolt on the rear of the head holding the line, I found best access by pulling the drivers side wheel and going in from the side. I think I ended up unbolting the fuel filter clamp. I got a few scrapes on my hands that day.
Remove the airbox, just below the throttle body and a little to the drivers side. About 1 inch forwards of the engine-trans parting line. Use a mirror- I have an old motorcycle mirror, a little 1 inch inspection mirror is too small. It is very hard to see from 'above'. I have not yet pulled the intake or AC etc, but given the rust on the coolant lines under the intake, I may need to.
A few months ago I sure could have used the transmission- would have saved me from putting an '04 into mine and having to do without AWD until I can get the control stuff sorted out! (shipping would have been silly though) If you were in driving distance no question I would load up on all kinds of bits, but nothing I need that's not avail. new for probably the cost of shipping big metal parts. Heck, I'd take the whole car for whatever the boneyard was going to give you if you were local! If you can hold the crank still and have some tools that'll reach 'em the bolts are pretty easy to get off. On is the challenge.
I just had my beaner trans out in February. The bolts are accessed at the top-rear of the engine, a little port that should be covered by a rubber plug. It took me a while to find it, as the port faces frontwards, that is, under the intake manifold. A good 6-point socket with the lead-in chamfer ground off attached to a flex-head ratchet is useful. A wrench with a pivoting socket-end would be good too. If you are going to pull the intake anyway, pulling the intake first (and attaching it last) will make the job a LOT easier. You can also just see the bolts from below, I actually started my bolts from the bottom using a 1/4 drive socket, extensions, and universal.
I'd lay money he'd say if the trans-x makes it work, then that's perfectly acceptable. Obviously it doesn't work in all cases, but when it does, there's nothing 'cheap' 'shoddy' or 'improper' about using it, and that's what's causing the pushback you are seeing- you are essentially calling everyone who has had success with it a 'cheap hack' for 'not fixing it right'.
I disagree as to the classification- if the problem is a seal that has shrunk, and something will un-shrink the seal, and it will last until you should be changing the ATF anyway, I'd say it's fixed. Your argument could be applied to, say, the ATF itself. "Car shifts hard. Changed the ATF and that masked the problem, shifts nice now, but didn't fix it because in 60,000 miles the ATF needs to be changed again". But, if it didn't actually work, then in your case sure, it didn't fix it. I saw a good description of the actual seal that causes the (classic version of the) problem, I thought it was in this thread.
Just be aware the usual strategy of 'right turn it gets quiet means right bearing is bad' (and vice versa for left/left) sometimes isn't true... I had a front on my '03 that tried to trick me. Bad left bearing got quieter when it was loaded up in a right turn.
2 bolts and the caliper comes off the pad frame. No need to pull the line/hose off the caliper (unless that's the caliper you are replacing). 2 bolts and the pad frame comes off. Struggle to pull the rotor off, get it a little loose, then give up and de-adjust the parking brake cable and de-adjust the star-wheel adjuster. If it has a lot of miles on it, be amazed at how rusty and cruddy the parking-brake bits inside the little drum are. At 200k mine is ready to have everything inside the little drum replaced, even the plain metal bits are getting sketchy due to rust.
