CNY_Dave
5
Everything posted by CNY_Dave
True- I can plow through 18 inches of powder no sweat, if it's wet snow I can drag the belly just a little bit before I'm high centered, especially since the car 'planes up' on the snow, the snow under the car takes some of the weight, the tires ride up packing the snow under them, then they 'break through'. Time to shovel! Here we get lake snow from the great lakes, often the only term for it is 'greasy'- it's like driving on whipped butter, no matter how much or how little. Subaru with good snows, extreme care required. Lesser tires, fergetabboutit.
Found a lot of water on the rear floor. Apparently rust holes in the fronts of the rear strut towers is a 'thing'. I riveted in some aluminum flashing 'splash guards' from underneath to get me through the winter. Inner fenderwells in the rear are rusted away too. Have to ponder fixing, and if fixing, as was or with some fender clearance for fun.
On a circuit board that is on the wiper switch itself. They are traces on a circuit board. The switch comes out fairly easily. You could snag a switch cheap and mod it and swap it, if you put in a forester switch you also get the option of having the rear wiper on all the time, not just intermittent. Not useful very often, but once in awhile I use it.
Just an anecdotal data point on oil pressure and viscosity. Buddy had a high-miles honda, way over 200k maybe near 300k miles, with the variable valve timing, started throwing an actuation code. The actuator was being told to whatever and wasn't due to the oil pressure being a bit low, or the oil pressure was supposed to trip a sensor, something like that. Shops wanted a ton of money to mess with it, I just told him to go up a grade or 2, forget if he went 5-30 to 10-40 or to 20-50 (or maybe 15-40), but it bumped the oil pressure enough to keep the car going for a few more years until all the suspension parts failed.
I grab my ABS sensors with a pair of channelocks (slip joint pliers, with 5 or so width grooves) right where it goes into the knuckle and grip really tight and work it back and forth while giving it a shot of penetrant now and then. Slowly work it back and forth, takes a lot of gripping force and a lot of twisting force.
- 46 replies
- knuckle
- snapped bolt
(and 4 more)
Tagged with:
bad tcu
CNY_Dave replied to subpoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Damn. Hot damn. Too fast! DAMN! -
The system that sets the code for the solenoid can only look at essentially the resistance of the solenoid circuit- too low a voltage and there's a short, too high and there's an open. Unless there's a wiring problem, a solenoid coil like that (as a sensor or actuator) fails as described, so the advice to change it is good advice.
