CNY_Dave
5
Everything posted by CNY_Dave
Oh hellyeah, I am going to check the snot out of it as far as possible before attempting to fix or replace anything. Yeah, no flashing AT light, but a clear-as-day code 93 from the gerblinky-blinky AT temp light when put into diagnostic mode. I even snagged a video of it so I could be sure. This was a junkyard trans, it wouldn't be that hard for the yard guys to have hit the sensor or pinched a lead. I did have to straighten the ATF dipstick tube by a fair amount.
I would say if this is a year and engine where subaru says to use it, use one bottle. Ivan has just seen too many engines and radiators and heater cores gunked up with magic spooge, so he riles against its use. My H6 head gaskets were seeping externally a little, so I used one bottle, and they certainly seep less, so I am not against using it, but if one doesn't help, I don't think 2 will.
No core. That was a key part of the decision towards not fixing, but replacing. They have a 90 day parts warranty, I almost want to price out the full harness instead of swapping my sensor. The harness includes the 2 speed sensors, the turbine speed sensor, and all the wires and connectors that go inside the pan. I bet it's expensive! If there is little to no chance I did whatever made the sensor not work, I might try and wrangle some scratch from the yard, after telling them what the whole thing costs.
Just looked in the service manual- you have to replace the entire harness, drop the driveshaft, drop the pan, pull all the connectors from inside the pan, drop the full exhaust to replace the VSS? Can't imagine what that costs, since there are other sensors on the same harness. I assume people just cut and splice the wire when they have a spare VSS from another trans, as I do. It's not some messed-up impossible-to-splice wire, is it?
96,000 mile used trans, from a 2004 LL Bean H6. Got it bolted in, trans is filled to the mark on the stick, on the jackstands the rear wheels do spin in all gears. Took it for a test run, by chance it was snowing. 1, 2, 3, D, the rear wheels do not drive until I get the revs up to about 3000 with the fronts spinning, then the AWD kicks in, and there is a bit of a groaning while it operates. Revs drop below 2500 or so and then it's just the fronts again. This wouldn't seem to be a grooved clutch basket, or any other post-torque-bind symptom, based on what I have read for the past few years. Any thoughts? Is the duty-c external? In the pan? in the rear case?
Got in almost 2 hours this morning, then went to the model plane club's annual lunch, got back to work about 4:30. Had to modify the transmission jack and do some judicious tilting, but it's out. I had to put 2 pieces of 12x2 under each jackstand and lower the rear to the ground. The trans jack (with the extension ears I added so the pan would not hit) is about 9" high fully lowered, but it was worth every cent getting it out, and will doubly be so going in. One of the bottom bellhousing studs stayed in the block, the other threaded out, I wonder of putting it in is easier with both in or both out? I bolted a 1/8th metal bar between the radiator support and a mount on the intake, motor stayed nice and stable. I was hoping to get this thing all wrapped up by sunday afternoon, that's sure not gonna happen! It looks like the diff oil was pushed up the dipstick, no idea why that happened, it wasn't filled with trans fluid or such.
AH-HA HA HA HAHA! Jokes on me, not sure I can get the car high enough to get the trans out. I always thought those jackstands and my jack went pretty high. I'm going to have to put boards under the jack, and under the jackstands, and probably lower the rear off it's jack stands a bit to get the nose higher. If I've led a virtuous life, I might not even have to take the trans off the jack and put the new one on the trans jack under the car. (in other words, I'll have to)
