CNY_Dave
5
Everything posted by CNY_Dave
The mid-pipe bolts were replaced with big springs a long time ago. Most of the header studs just threaded right out of the head, 2 threaded off the studs. 2 of the torque converter bolts would have broken my 1/4-drive ratchet, I always have that happen so I grabbed the blue wrench and bent a 3/8ths extension into a U. If that didn't work I would have brazed a socket to a bar. The ideal tool I think would be a socket-end wrench where the socket end pivots, I have a 1/2 inch and a 9/16ths but no metric. I used the U extension to break them loose, then I used that spline-drive that has a big external hex on the end to turn them until they were finger-tight. That turned out to be a lot easier than the 1/4 ratchet. The big hex end fits a 13mm box wrench so I put a bolt into the socket and bolted the wrench to the end of the socket. I threaded a long skinny mag pickup tool under the manifold from the side and stuck it to the bolt after it was finger-tight so I couldn't drop the bolt, was very helpful, but that trick won't work to get them started. Is it helpful to back the converter out of the flex-plate? All the bolts are out but the converter still turns with the engine, presumably the center end of the converter is stuck tight into what on a manual would be the pilot bushing. I am not looking forwards to starting and then tightening those bolts.
What sealant?
CNY_Dave replied to samm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I know ultra-grey is the go-to equiv for fuji-bond, the sealant for the oil pan. On my H6 the pan gasket is under the full depth of the oil, I replaced my pan recently using the UG and so far so good... -
The dealer 'should' have a new snap ring, and TC seal, and driveshaft seal, and filters by Friday, when I'll need them. I didn't see any kind of a seal inside the TC, or inside the trans, other than the seal for the converter itself, but that doesn't mean it's not there. When you get the TC seated can you feel the drag of the pump when you turn the TC?
OK, I have my boneyard trans, they pulled the torque converter and so I looked at how to put it back in. It looks like you slide the tube that drives the pump all the way off and out, then insert that into the torque converter, get the snap ring settled into place, then slide the whole kit-n-kaboodle into the trans. Looks like they munged the snap-ring, though, is that common or indicative of a heavy-handed disassembly? Should I get a new ring or straighten it? Is the snap ring really required? I don't want to get this thing in and then find out they broke the pump- any way to feel for it being 'right' after getting the TC back in? Pics...
