CNY_Dave
5
Everything posted by CNY_Dave
The puller pictured won't stand up to serious force (the bolt will bend and spring back when hit, absorbing the force), the very short heavy cast one is also much less likely to warp the flange. The subaru tool has a big round metal plate and bolts to all 5 studs, they obviously know some are going to be a real bastard. http://www.pepboys.com/product/details/9911422/
I hate to ask if you knew to tighten the 3-jaw then hammer like a lunatic on the screw. Then, when the screw loosened, to tighten and hammer some more. Kroil is good, ATF plus a solvent (wd-40 as a solvent in a pinch) is almost as good. Pep-boys has a good fixed-jaw 3-jaw puller, for borrowing or it's about 30 bucks to buy.
If I hear the noise with the fronts up and the rears on the ground, FWD fuse in, I'm going to stick a nail in it and call it a part of the trans I'm not at this point willing to mess with. I might do this with all 4 wheels up and the e-brake on. I think with the front wheels on it'll load the noisy part enough I'll be able to hear it.
OK, have what sounds like a front opinion (or front final driveshaft) bearing noise, pitch changes at about 4x road speed, but not much gear whine. To me this means front pinion bearings, some bearing on the front pinion drive shaft, rear output bearing, or maybe the driveshaft carrier bearing. Noise disappears with removing the load (just enough throttle to coast, or just coasting), amnd noise was not changed at all by inserting the FWD fuse (FWD light lit). Other than trying to hear the noise with the car on stands, then inserting the FWD fuse and stopping the rear wheels, any other way to absolutely rule out the rear shaft bearing in the tailhousing or the carrier bearing?
I've found two used ones with about 100k on them for $800-$935, with a parts warranty, both within 50 miles, now I'm trying to track down a driveshaft. Also now need to rule out any noise other than pinion bearing or front output shaft bearing, before I shell out $800. FWD fuse made no change in the noise, so I figure it's not anything associated with the rear driveshaft (carrier bearing, rear output bearing)
Yeah, I'm going down the list of options at this stage. 800-1200 to replace the pinion bearing, 650 of that is just getting the trans in and out. Rebuilt trans that I put in, I have no idea. 'Junkyard' trans via car-part . com, 800-1500 or so, with a few in driving distance. Not sure yet if any of those are rebuilt.
