CNY_Dave
5
Everything posted by CNY_Dave
Some goo is seeping out of a crack on the rubber insert on my crank pulley, and it's starting to rub the case. Biggest piece of info I'm looking for- is there a magic spot on the flywheel where the crank can be held? 2nd- I assume the oil seal rides right on the pulley like on every other chain-driven cam engine? I assume the pulley is different from the H4s.
I was willing to bet if I pulled the switch apart I could find the right circuit-board trace to cut (taking apart the un-dissassembleable is a talent of mine), someone pointed me to this: http://offroadingsubarus.com/spraythenwipe.html There's a resistor you pull, and it disconnects the washer button from the intermittent wiper control.
Has anyone set it up so the washer button does not turn on the wipers? To me this is the most monumentally stupid feature conceivable, at least for those of us who have winter! I am sick of the wipers dragging across a bone-dry dirty windshield before the squirter starts squirting, and don't even get me going on the agony of the line being frozen or the reservoir empty.
I just had a windshield replaced, took advantage of having it out to fix all the rust and rust holes in the channel. This 10 dollar any-auto-parts-store chuck-it-in-a-drill worked like nothing I have ever seen before, it ate through the paint, the rust, and even the windshield goo, but didn't really grind the bare metal: It's like a sandblaster that makes much less mess.
The 2004 used the in-tank filter, and the new filter (avail. aftermarket) comes with a new (deeper) cap that fits. 35 bucks i think. It is rumored the '04 metal cap alone is available from the dealer, but far from confirmed. I think we need to get a worldwide network together of people harvesting their caps from their 4cyl outbacks if/when they replace the pump.
3.0
CNY_Dave replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
'Close' in bore and stroke? So you'd have to bore your engine? What about the piston compression height, deck height and chamber clearance/squish?
