Everything posted by CNY_Dave
What is this under the glove box?
CNY_Dave replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like a chime.
Wobbly OBW
CNY_Dave replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to check all the bushing and ball/tie-rod joints post-haste, I'd say. Wheel bearings, too.
Best place to buy axle shafts
CNY_Dave replied to Timberwolf530's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I just ordered 2 rebuilt from EMPI via auto parts warehouse, a bit over 75 beans including shipping and no core charge. That's about what they are at NAPA (my NAPA axle has been holding up so far), so what-the-hey, I'll try 'em. I really couldn't cost-justify spending about double for a unit from MWE or Raxles.
Clunk Noise on front left wheel - Legacy
CNY_Dave replied to gciriani's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpeaking to the generic case, any worn suspension component can cause a clunk as it shifts from one location on its bushing/pivot to another, including wheel bearings. First thing to check with any clunking is all the ball joints, inner and outer tie-rod ends, wheel bearings, control-arm bushings, sway-bar bushings and end-links, and strut bearings.
99 legacy rear spindle wont give up axle
CNY_Dave replied to natext6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNaw, when you have it tightened down on the axle you whack it with a hammer and the force transfers through the screw without the screw moving. Tighten, hammer, tighten, hammer etc until it pushes out just with tightening the screw. Also, with a lot of preload all the bits will deflect and stretch and the axle can move a bit and actually keep tight against the axle.
Odd noise - vibration (2000 OBW AT)
CNY_Dave replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCurious- were some of those cars equipped with VDC? The U-joints tend to go quicker on those since the rear wheels do most of the work (45/55 normal split).
Cooling fan help, friend is traveling and having a problem
CNY_Dave replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my '03 the magic green connector does cycle the fans.
CNY_Dave replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt would make sense the symptoms of that bearing being bad/loose would mimic a bad DOJ.
Cooling system vacuum?
CNY_Dave replied to tlott01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the radiator cap and overflow hose are working properly it can't pull a vacuum, but if you are starting cold with rad full and fluid in the overflow, and then the overflow is empty, something is not right elsewhere.
CNY_Dave replied to gciriani's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe big axle nut in the center? Whoever last had their hands on it goofed, it should never come loose! I wonder if the wheel bearing was loose because of that or if the noise was the axle slapping around or in/out. The wheel bearing on that side might or might not be OK, and might fail prematurely. Or maybe not.
CNY_Dave replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's the side bearing for the front diff, the one that carries the stub axle, I think.
CNY_Dave replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNever heard of one of those going, maybe a previous owner drove with a very bad DOJ for a looong time...
Cause of not starting when gas low, then starting after 2 pumps of gas pedal?
CNY_Dave replied to mountainwalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe TPS is a potentiometer where a wiper rubs along a resistive strip. Exercising the wiper can clear crud out of the way or get the wiper to 'wipe' along a slightly different path. So pumping the gas could possibly affect how a bad TPS works.
CNY_Dave replied to gciriani's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTightened the bolt on the disk? Do you know which one he meant?
CNY_Dave replied to mountainwalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone is testing out the 2004 replacement fuel-filter that comes with a cap. The cap may or may not fit. Just that cap may be available at the dealer.
car is vibrating while accelerating ??? not tires
CNY_Dave replied to jheat71's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, this is exactly what mine did.
CNY_Dave replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFront or rear pinion or trans bearing, maybe the driveshaft carrier bearing. What is the pitch of the noise?
2000 Outback Fuel pump assembly metal cap is broken
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think adding a bit of metal on the outside of the cap would reinforce it enough to keep it from cracking again, I've done crazier and had it work. Having a micro-torch helps. If that other filter-plus-cap cap works for 35 bucks (or if the 04+ cap is avail from the dealer) that's a good bit easier.
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou know, those broken caps could probably be brazed or silver-soldered just fine. I'll do it if someone wants to send me a lid for which they'd be the guinea pig.
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the cap fits without the filter, just use the cap...
CNY_Dave replied to jheat71's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTie rod end? Ball joint? Transmission bushing? Is it a vibration, or a knocking? Were the wheel bearings checked? When you speed up does it speed up with the speed of the wheels or about 4 times as fast? The axle could be shot and seem tight when the car is up on the lift. Make sure it gets checked with the weight on the wheels.
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe '04 part does look similar to the pic in this thread: http://www.subaruoutback.org/forums/66-problems-maintenance/26419-2001-subaru-just-shut-down.html
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis topic has seen a resurgence at http://allwheeldriveauto.com/subaru-service-seattlesubaru-fuel-filters-explained/#comment-121636 I'm 'dave', who will fess up as 'phil'?
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI isolated the big pic:
420 420 420
CNY_Dave replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre they putting something weird in the gas? Does E10 or E15 (added as an oxygenator) leave too much O2 in the exhaust?
