CNY_Dave
5
Everything posted by CNY_Dave
Does this critter have an 'accident' switch that kills the fuel pump if it thinks the car has been in an accident? Had a car once that used the oil pressure sensor for that... other cars have an impact sensor, might be the little bit the pump runs when the key is 1st turned on supplies enough pressure to idle for 10 seconds or so, but the pump never keeps running.
So when torquing the axle nut were there a bunch of fairly difficult turns, followed by a very sudden increase in turning torque and then hitting the torque setpoint almost immediately? On mine it took a bunch of turns to fully draw the 2 inner races together, was wondering what the heck was going on. Once they met it hit max torque in less than a 1/4 turn.
When I pressed mine out I was very careful to give the area just outside the race good evenly-distributed support, after seeing how hard I was to press it out a) I have wondered if even the real $300 OTC tool could handle the task for one stuck in tight yeah, you could bend the knuckle if you can't support it evenly.
I snapped one of those suckers (same job but in the trans ) on my '80 celica (during a non-police car chase, yes I still got away), was locked in 3rd gear. Didn't have a replacement the next day (a sunday) and absolutely had to fix it- brazed that sucker in place. I would try to get the same type of pin, the load capacity of all spring/roll pins is not equal. Dave
Apart is easy, you just rotate the end (the thing the axle goes into) to one extreme and then pop out the ball that presents itself with anything that's softer than the cage or the ball. (after you remove the axle shaft, of course) Putting together, now that I have never even tried. Now what is the 'pipe trick'? Never heard of it.
