CNY_Dave
5
Everything posted by CNY_Dave
What I'll throw in is if you are really going off-road this may be a useful mod, especially as having the front/rear locked together can be quite useful going down-hill, but 99.999% of the time you won't get a real gain with the switch. If you are really going off-road, you'll want to think about what to do with the ABS... Dave
As a bit of general info, I'll add that it is very easy to get a subaru to torque steer, all you need is any situation where the suspension is deflected a bit and the driveshafts are no longer nice and straight and equal length. For example, there are some roads around here that are dramatically crowned (more due to subsidence than purpose), or if you have a bad strut spring up front. Dave
The phrase "Make sure that no crack or other damage exists. In addition to visual inspection, inspect important areas by means of red check" makes me think it's a chemical crack-check procedure. Read more: Subaru DL how do I change the head gasket(s) on a 87 DL w - JustAnswer http://www.justanswer.com/subaru/4a7q1-subaru-dl-change-head-gasket-s-87-dl.html#ixzz1T42o9T3f Dave
I have a comment or 2 or 3, we'll see what it comes out as... Under 300 bucks for a service job that requires a press? That's cheap! I bought a press to do my wheel bearing because I will use the press for other things, would probably not buy one just for this job. How much force can the HF or even the expensive hub-tamer achieve? My HF 20 ton A-frame press was pretty near capacity* (so call it 15T, heh) to press the large outer-race from the knuckle, can a screw-press (which is what the HF and hub-tamer devices are) achieve that level of force? * I say it was near capacity because I was using the included extension handle and I was just about hanging on the handle. Dave
