CNY_Dave
5
Everything posted by CNY_Dave
New Axle Nut?
CNY_Dave replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you decide to expose your weather-beaten (axle) nuts to the world, we don't need to know about it! Dave -
New Axle Nut?
If you re-use them, it's best if you can get a new part of the nut over the slot so you aren't re-bending the same staked spot. If both go back to the same spot, you could try swapping nuts side-for-side. Dave -
Outback mod?
CNY_Dave replied to WA2NTK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ralph, if that's horseheads NY, you mean it only snows half the year down south where you are? Dave (Cortland NY) -
Outback mod?
The beaners don't have the VTD/VDC. Dave -
The way the wheel bearing goes together, yes, it is unlikely too much torque will do anything bad. Beyond sufficiently 'tight' the wheel bearing clearance does not go down/preload does not go up as you torque the nut further. Doing my wheel bearings, it turned for a long time at low torque and then when the two inner races met the torque went up to spec within 1/16 or 1/8 of a turn. Dave
Could also be pad deposition onto the rotors, caused by getting the brakes good and hot then stopping with the brake on for a bit. This feels much like a warped rotor but the cadence is usually once/rotation as opposed to many times/rotation. If the steering wheel vibrates, that's what I'd call warping, if it feels like it gets pulled left-and-right that's the slower cadence I mean. Dave
