Everything posted by CNY_Dave
Should I buy 01 H-6 3.0 LLBean?
CNY_Dave replied to KaraK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNapa 6203-2rsj is one that fits. Unbolt the pulley and the bearing is lightly pressed into the back of the bearing. The tensioner pulley has a nut behind it that falls off (it fits in a hex recess so you don't have to put a wrench on it). Dave
CNY_Dave replied to KaraK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome 2001's had to have the chain guides replaced early, making the '01 a little less desirable. Unless you are after the trim package or do a lot of highway miles, I wouldn't say chase an H6, but if you do a lot of freeway/over 60 driving it's a useful upgrade. Mine sees almost 100mi a day, and it cruises a bit over 80 still under 3k rpm. Smooth, baby! Dave
Uh-oh... pulley freaked out
CNY_Dave replied to nfactr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm, if it needs to fit tight against the end of the crank and the face of the sprocket, but could only fit tight against one, I'd pick the sprocket. Filing the nose of the crank might move it back far enough you don't get a good tight (face) fit. If the face of the sprocket is munged, I'd def. get a new sprocket. Dave
2003 Forester Tail lights Stay On
CNY_Dave replied to sashalinda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the little switch on the top of the steering column 'on'? Dave
Sluggish performance? Check your alternator!
CNY_Dave replied to Allpar Mod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn ammeter that uses a very low resistance resistor is pretty easy to install if anyone really prefers an ammeter (it's a voltmeter that goes across a low-value series resistor). Dave
my car EATS wheel bearings
CNY_Dave replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many tons of force can you get out of a screw-type hub tamer or bearing installer? My 20T press felt pretty close to the limit on my front wheel bearing job. Dave
CNY_Dave replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are steps in the press process where you have to be very careful about what is actually taking the strain. Also, if you put any weight on the wheel bearing before torquing the axle nut fully, that can damage the bearings/races. Dave
Normal front diff. sound???
CNY_Dave replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds it. Jack the fronts up, chock the rears/ebrake, put it in neutral, spin each front while listening/holding the spring. I had a bad wheel bearing that was not loose but was noisy- could not spin it fast enough by hand to hear it, but the 'noise' could be felt in the spring. Dave
one shot front wheel bearing?
CNY_Dave replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr you need to have a lot of old bearing races and metal bits around to stack up... There are indeed a few points in the process where you need to be sure about what's taking the strain. Dave
horrible exhaust sound at start up (then goes away)
CNY_Dave replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they want to put on a cat because the bolt flange is rusted, there is a slip-on repair flange that works just as well. Dave
CNY_Dave replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis can be the converter-pipe donut starting to let go. System heats up, things expand, small leak seals up. Dave
WTB Outback.
CNY_Dave replied to zaskar23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf there's a lot of highway driving involved the 6 is nice for that. Dave
Outback '01 - Oil pipe leading into filter housing starting to rot
CNY_Dave replied to beenaroo_01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine's an H6. Dave
CNY_Dave replied to beenaroo_01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a coolant pipe, not an oil pipe (still needs fixed, just less impact if it leaks). All the oil stays in the base. Dave
I went to the evil place
CNY_Dave replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't seen that type before. Available where? Dave
How long will this last? Exhaust flange.
CNY_Dave replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a situation like that but quite a bit worse- I stuffed a silver metal exhaust donut into the gap and slathered it with that hardening exhaust-repair goo (which is actually contains the stuff they put into the clunkers to ruin the engines). A softer composition exhaust donut would probably not even need the goo. If the flanges are toasted by the time you have to re-do this, those flange savers are like magic. Dave
What bearing ???
CNY_Dave replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNapa has 'em, 6203-2rsj, easy-peasy to put 'em in. Tensioner pulley has a nut that likes to fall out in the back when you pull the bolt. Dave
Please help - '03 LLB OBW turns over but won't fire
CNY_Dave replied to live2fish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say the global misfires and the lack of good ground are consistent with it being able to idle but not take any throttle. Tracking down a bad/missing ground connection without a wiring diagram will be tough- you are going to have to check all the grounding points that are anywhere near the injector loom, and work backwards into the loom until you find the bad spot. The problem with the ground (if this is the problem) is likely right at the grounding point, very close to it, or where the harness gets chafed/pinched by something. And, you really need to get a working fuel pressure gauge on it- there could still be a problem there. Dave
are these o2 sensor non foulers stock?
CNY_Dave replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 'trick' is usually applied to the rear sensor only, to get rid of a real or bogus 'cat efficiency' code. Dave
Brakes that work and then don't?
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould even be a bad wheel bearing pushing the pad back into the caliper, this one's wide open. What the pedal did is key, as mentioned. Dave
Brake cleaner vs Carb cleaner
Carb cleaner dries about as residue-free as brake cleaner, and if you're cleaning just unpainted metal parts, that's about all that matters. But as said, carb cleaner is worse for you and might chew the heck out of rubber, plastic, paint, skin, maybe pads and shoes, and sure as hell will wreck your eyes. Dave
CNY_Dave replied to live2fish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWould ir start if you gave it a little throttle? Dave
CNY_Dave replied to live2fish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel pump could be giving flow with no real pressure, or pressure with no real flow. Really need a gauge on the rail while cranking. I thought on some subies, if the MAP/MAF went bad it might not run at all, but would run in limp mode if it was disconnected. Also, is tapping the cam (crank?) sensor one of the tricks? Dave
03 Outback H6...whining from front diff area?
CNY_Dave replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you had time with a bit of clay and the right acid you could dissolve the bolt right out of there... I think there's even a way to speed the process with a bit of electricity. Dave
CNY_Dave replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, I'm just maxxing my H6 knowledge. Used is always a crapshoot. Dave
