CNY_Dave
5
Everything posted by CNY_Dave
Confirming which side by how the noise changes while turning can be tricky. Usually when you turn to put more weight on the bearing, the bearing gets louder, and when you unweight the bearing, it gets quieter. That is, a bad left bearing gets louder in a right turn. My '03 was the opposite, the more weight on the bearing, the quieter it got. The left was bad and it made less noise in right turns. The only way I was able to diagnose it 100% was to jack up both fronts, put it in N, and spin each front while holding the strut spring- the spring magnified the vibrations. Dave
Too loose and the inner bearing races could separate under load, that'd be BAD. Too tight, and you could distort the bearing races, that'd be BAD. Too tight but not tight enough to distort anything would be just fine, as you cannot over-preload by torquing the nut too tight. My gut feel is a little loose would be worse than a little tight, but at those torque specs that's not something you can tell by hand, so- Torque it to SPEC since you need a torque wrench anyway. Dave
The mechanic might be retired from the pit crew of Parnelli Jones for all I know, but: There are a few steps in the replacement where you have to be quite careful what presses on what, and you have to make sure no pressure is put on the spindle before the nut is fully torqued- Add to that a question about what grease if any was in the bearings that were purchased- Further add that if the hub was damaged by the bad bearing the damage can be very hard to spot- Is this mechanic experienced in subarus? I hadn't heard about the bad knuckle in 2001 either. I am 99.9% sure the knuckle is the same no matter what engine, and I think it's the same for a legacy or an outback. Dave
The key here is that sometimes the best way to stop is to lock 'em right the heck up. The ABS won't let you stop, but locking the tires up stops the car almost instantly. The circumstances where this happens do not occur every day, but regularly enough that you have to be ready to deal with it. Dave
Just because you haven't had it happen, doesn't mean it doesn't happen despite the best of tires and vehicle condition. There are times when it happens because you're coming in a bit too hot, then there's times when the ABS will coast you along no matter how slow you're going- usually down a fairly steep hill. Mind you I'm in the camp of leaving the ABS connected and just dealing with those few times the ABS wants to coast me down the hill by employing appropriate strategies. Dave
