CNY_Dave
5
Everything posted by CNY_Dave
wiring woes
CNY_Dave replied to Lacysboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Every other dang year (just about) has a plug in the back where you plug-in a commercially available trailer-light adapter box- I would be surprised if the '05 is not the same. An adapter box is required in any case since trailers usually have integrated brake/tail lights. Dave -
If I ever get around to modifying my '03 headlights so that the low-beam filament turns off when the high beams are on, I may need to disable the DRLs. There are times when i would like to turn them off at night (sometimes you have to go stealth, and the brakes drag a bit with the Ebrake on one notch), but in general I really don't care if they're on. Dave
If the spark can be retarded arbitrarily far, the octane could be arbitrarily low. The question I guess would be can the computer retard the spark sufficiently far? I think it can, and I don't worry about running 87 (heve never heard pinging or knocking), but I don't because it runs so much better on the higher-octane stuff. Pre-ignition is devastating when it occurs early in the compression stroke, but is not caused by too low an octane, really, it's caused by hot bits in the cylinder igniting the charge early in the compression stroke. It can bend a rod very quickly if it happens early enough in the stroke. The hot bits can be carbon or a plug that's too hot. Spark knock or detonation is the term here. The octane rating of the fuel really has only a little to do with the ignitability of the fuel, if the fuel ignitability was low enough that 10 or 11 or even 12:1 compression were enough to ignite it, we'd all be seeing cetane ratings on gasoline pumps, as opposed to just octane ratings (and unlike a diesel, low cetaine ratings would be what we wanted). Dave
Add a few more ingredients to the ATF mix and you have genuine Ed's Red. I would like to see creepage rates through rusty threads compared, but that's be a tough protocol to set up. Maybe the ones that did best here didn't *lube* the best, maybe they just *crept* the best. "According to Ed, “Ed’s Red” will flow at -65oF and won’t carbonize at 600oF. It has seen use by both the FBI and the Army Marksmanship Training Units." http://blog.captivereefing.com/2008/04/17/eds-red/ Dave
Subaru's are famous for having no torque steer- as long as everything is set up right and the road is dead-nuts flat. I get no torque steer on a flat road, and sometimes quite a bit on a road where there is a dip where the right-hand wheels go (similar to a road crown but more severe). As soon as one side is compressed more than the other, the subie gets torque steer just like lesser FWD vehicles. Dave
What I would clarify is that no matter how much you torque the nut, you will not increase the force/pressure on the rollers (or balls) (which is what I would call preload). The preload is set by the dimensions of the inner races, and axle nut torque (axle stub stretching) need only be sufficient to keep road forces from separating the two inner races where they meet. Dave
Unless I see a manufacturer document or a DOT doc or a set of alignment specs that are asymmetric, I am going to call BS on pulling right by design. The concept is so damn flawed that it sounds like the stupid kind of thing manufacturers or the DOT would do/mandate, but actual cases where it would help are just about nil. Not to mention the compromise in fuel mileage and tire wear. Dave
That's what I think, but I distinctly remember there not being a step there because there was no hint (on the assembly) on how far to press in the hub. It was easy getting the outboard inner race off the hub because there was a gap between the inner race and the outer edge of the hub. It seemed there was the possibility of pressing the hub in too far and pressing it into the outer oil seal. Well, it's been 10,000 miles or so... Or maybe the axle nut was never fully tightened, but I have to imagine the bearings would not last so long. Dave
The preload confuses me a little bit. I think when properly installed the inner faces of the two inner races are supposed to be in contact with each other, but I can't for the life of me figure out what keeps them in contact other than the inner race friction fit on the hub. When you press the hub into the inner races, you don't drive a wider portion of the hub against the outboard inner bearing, the outboard inner bearing could move further outboard if it was a loose fit on the hub. The inboard inner race rests against the face of the outer CV joint. The only time you set the bearing preload is when you press the hub into the inner races by driving against the hub and supporting the inboard inner race. That is, the friction of the hub to the outboard inner race drives the outboard inner race against the inboard inner race. As long as the 2 inner races are touching, the preload is correct. If the outboard inner race is a loose fit on the hub, it may never be driven against the inboard inner race. Or is there a step in the hub I'm forgetting about that bottoms against the outboard inner race? Dave
My '03 is starting to have problems with opening the hatch. On mine the handle is not returning fully, so if I give it just a little 'push' all the way to the normal (rest) position, it clicks and is good to go. Do you pull the cover off the inside of the hatch to access it, or do you pull the 2 screws that hold the hatch handle/license plate lights? Dave
