CNY_Dave
5
Everything posted by CNY_Dave
If the rears have wear, and you replace the fronts, the circumference won't match. Did the edges on the front wear from a bad alignment? Low pressure? Can you just rotate the tires- it could be edge wear just from normal turn scuffing, the front edges always wear a bit more than the rear edges. Dave
Heavy Shoes?
CNY_Dave replied to SVX281's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just this morning I was wondering if I'd get better mileage with lighter steel wheels... Dave -
Let me weigh in with a few thoughts- 1) I can find no proof HHO (Brown's gas) actually exists, or can be made. If there's a cite I missed, lets go check it out! 2) Water injection is a tried-and-true method for running a boost pressure, compression ratio, or load (high throttle high load) that you ordinarily couldn't. The P51 mustang fighter used water injection (50/50 water/methanol) 3) I have seen a claim where using water injection, the water breaks into hydrogen and oxygen into the combustion chamber- Bunk! 4) If you take an engine that doesn't detonate, ping, pre-ignite, etc. etc. and use water injection on it, you don't get more power or better mileage. Dave
My H6 loses a small amount of power on regular 87 vs 89 or 92. The loss is not in the top end, its in the mid-range. The mileage difference is small enough I don't think premium will pay for itself. caveat: here in NYS the winter blend is cruddy enough that the power loss on 87 is noticeable. 89 or 91 gets rid of it. My mileage on winter-blend is noticeably worse, too. I'm getting just shy 27 or just over 27mpg on 87, mostly highway at 70-73 mph, with some fair hills on my commute. Dave
Well, if the rear driveshaft bolts in at both ends that's pretty easy and straightforwards. Take it out, and pull the FWD fuse. Then you could go nuts and pull the pumpkin and the half-shafts at your leisure. Just remember (I think) you need to put in a half-shaft outer stub end to hold the wheel bearing together. Dave
Well, it takes *some* extra fuel to accellerate the extra mass, but yeah, that's a "one time" thing on the highway. More loss if its hilly. Don't under-estimate the powerloss in the rear shaft U-joints, rear pumpkin, and rear CV joints. And if its slipping, the powerloss in the front/rear clutch. Dave
Just to examine this issue to the fullest degree possible- how much weight would be shed, and how much would mileage go up, if you pulled the rear driveshaft, the pumpkin, and the rear half-shafts? You could just use the shells from a pair of outers to keep the wheel bearings together. Would you get 1? 2? 3 more mpg? All that stuff weigh 50 lbs? Dave
Holy crap! I have a somewhat hard time believing the amount of fuel there'd be just from the fuel-rail pressure would be enough to hydro-lock the cylinder, but it was either that or something else got down there I guess. I mean, if they hydro-locked so easy, I'd assume ones with leaky head gaskets would be self-destructing all the time, no? Even though most leaky head gaskets seem to leak out, you'd see some doing this. Dave
You know, maybe the key is to weld something to the pin that will let you get a lot of leverage on it, like a big nut right down where it goes into the receiver. Then apply a lot of torque, and when it shears it just might shear flush with the hitch. Find a nut that'll just fit over the pin, cut the pin so it just protrudes from the nut, hit it with a mig welder or a gas welder (or even braze it), and turn that SOB. Dave
Hmmm, heat's going to be of limited use, because as you heat the pin it will get tighter in the hitch, but if you get it all hot you might be able to cool the pin very fast, which might create a small gap that will wick up some PB Blaster, or better yet, kroil. You could weld some more metal to the pin (for leverage) and try and rotate it, just a little will let freeing oil creep in. Maybe someone really good with an acetylene torch could cut the pin down enough that the whole hitch would slide out with the pin still in place. It'd be using the torch to divot the pin bit by bit. You could pull the whole shebang, cut the pin flush on both sides, and drill it out with a drill press. You might be able to drill it out without a drill press, but that'd be slow and burn a few bits, I'm sure. The easiest thing to do is hit it with freeing oil a coupla times a day for a week or so- try the easy way 1st. Dave
