Everything posted by CNY_Dave
2002 Outback H6 VDC ???
CNY_Dave replied to Yellow_Car's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot as knowledgable as some, but did it have VDC badges anywhere? I do know not all H6s ( in the US of that vintage) have VDC. Dave
First time working on the H6
CNY_Dave replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy '03 H6 with 60Kmiles is a trifle whiny. Just loud enough to hear with the windows down. Dave
[bangs head against desk] Torque converter woes
CNY_Dave replied to classact2575's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll take a SWAG and suggest instrumenting the lock-up lead and see if/when its getting the signal. Dave
#$%$#$ Cruise control
CNY_Dave replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I'm glad its not just me hatin' the cruise control!! I've had my graspic DS2s up to about 115, they feel a little loosey-goosey on the turn-in and then settle pretty much OK. Dave
what make a 4eat shift??
CNY_Dave replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, at worst it would cause it to downshift only at the same point it would if the cruise was off, if it just tells the TCU the cruise is active. Dave
CNY_Dave replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless the cruise control can be 'tuned' better (BTW, the car does not slow much at all before downshifting), then does anyone know if cutting that 'cruise control' signal lead would do what I'm hoping for? Dave
CNY_Dave replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd add to that: - the torque control signals? - the dropping register signals? Dave
CNY_Dave replied to scrapdaddytatum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see a coupla things there... 1) I wonder why the ABS runs a signal in- no traction control on this critter... 2) I assume "Transfer Duty Solenoid" is aka the "Duty C" solenoid? 3) If I were to cut the ^%%^^ cruise control signal, will it stop being MORE prone to downshifting on hills with the cruise on? 4) If I take that same cruise control signal and run it to a switch (with the right voltage, aka gnd or +5 or +12) can I use it as a 'sport shift' signal? I realize 3,4 may induce some heartburn as the subie literature says the trans is supposed to be less sensitive to loading with the cruise on, but on mine, I can assure, attest, and prove that ain't the case! With the cruise on, it downshifts up hills that don't require a downshift, and if I kill the cruise I can maintain speed with no downshift, so I'd really like to keep the TCU from knowing the cruise is on. Dave
2003 LLbean OBW- crappy handling
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey had about 30-31 in 'em last night, was about 42 degrees, 'at speed' on the interstate last night they seemed to be squishy, but then 'settle in' on the tighter curves. Dave
H6 Crankshaft Pulley Bolt Removal
CNY_Dave replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs an H6 owner, curious as to the repair and what mileage its occurring at- Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTires make a difference? Hogwash!!!
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget we're talking about my piggy LL bean with extra option weight and its a wagon, to boot! A little bit more weight and a slightly higher CG than some of what other folks here are driving. Not a big difference, but its there. Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, no, that is wrong. When the body rolls Left/Right, the CG moves Left/Right, the further the CG moves the more the weight will transfer. Simple physics. If body roll didn't affact weight transfer, SUVs wouldn't roll over during accident avoidance maneuvers. When the car turns right, and the body rolls left on the suspension, the CG moves left as well. All weight transfer is not because of body roll, but the amount of body roll affects the weight transfer. I'm, not talking about how to limit the roll; but, if you lessen body roll, you limit the weight transfer. Or are you talking just about front/rear transfer? Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt wasn't necc. the case today, but being able to do 'the flick' if need be can be a life saver. Did some practice on the way home and I have a much better feel for it. Pretty sure if there was less body roll there'd be less oversteer. And also, of course, less body roll would cause less weight transfer. Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd firmer compression damping will slow the roll rate, which will lessen the total amount of roll. Dave
Brake Fluid flushing method ... discuss....
CNY_Dave replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe brake lines are skinny enough I don't think it'd really matter- even if there was something in the fluid that wanted to 'float', it'd be trapped. Kinda like a weather inversion layer. Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust like us dirt bike guys say- "When in doubt, gas it!" Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"C" is ineed part of it- had my truck so long, I could tell you very well exactly what it could or could not do, and how fast, and how far out the assend would slide, etc. The sube I've had only since October. Need more practice in the subie! I've gotten lotsa snow practice, not much dry-pavement slaloming yet. Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou mean those nasty stockers? Suck in the rain, I'll tell you that much. Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do have to confess I have not practiced with this car as much as I would like. Usually, I get to know exactly what the cars limits are fairly quickly but I've been slothing off. Dave
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo VDC. And yeah, had I been a n00b, that would have been a spin into the ditch. Throttle was neutral, though (just enough to maintain speed, about 65mph). I know stiffer struts (firmer damping) would help a lot (that's why my ranger handled insanely well for a pickup, man could that thing carve an on-ramp), just wondering if this is subie-normal, or are my struts shot at 5 years/60Kmiles? Wonder if the 6cyl makes this better or worse? Dave
In general, handling isn't horrible. Quick lane-change today (think accident-avoidance maneuver) was a bit ugly. I mean, a lot worse than my old '92 ranger pickup. Dug in with a lot of roll on the primary turn, fishtailed pretty bad on the straighten-out portion, and she wagged a few times after that. Granted, I have Dunlop Graspic DS2s on there, not fabulous dry-road tires, but maybe the struts are gettin' weak? TP is up to spec, just had it aligned. I know its not a bloody porsche, but it did seem a bit worse than I'd expect. Dave
Check this guy out...
CNY_Dave replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou insist nothing is moving, but the engine is rocking back-and-forth. Perhaps this is a vibration source? I did post a technical analysis of possible causes, and I didn't rip into you, so lets hear what you think of what I said? Dave
CNY_Dave replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDunno how cross-forum posts are tretaed here, but... http://subaruoutback.org/forums/showthread.php?s=&threadid=11678 I for one am treating his Q as a serious question (out of politeness), and I'll enter into discourse with him as long as he's civilized (3, 2, 1...). What do you guys think of the axle-length theory? Dave
4spd auto- clunk on downshift
CNY_Dave replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been asking myself, is there any way this could be the front/rear torque-split clutch? I can posit a reasonable theory that a downshift at high speed could alter the trans fluid pressure, which could cause a tightening/loosening of the AWD clutch, but since its on dry pavement I can't really spin that into something that'll cause a clink. Dave
