My Subaru is having many little electrical problems. For one, the idle is not completely kicking down. This is a non-turbo, 5-speed, 4-wd EA-82 w/ 210,000 mi. on it. It will kick down and then rev up, kick down, rev up, kick down, rev up repeatedly and quickly. Each cycle last about 2 seconds. Adjusting the minimum airflow doesn't affect the high-speed idle. The car will drop the idle to below 1000, like normal, if started after the car has been warmed and shut down. Once I drive off again, though, when I come to a rest, the idle cycles again. When starting from cold, the fast idle works normally.
Also, the lights rise and fall in brightness on my dash. The voltmeter reads at about 17 volts charging and I believe the brightness of the dash lights corresponds with this. I know it sounds like the regulator, but I'm not sure.
Also, the oil gauge doesn't work, never really has. We've had this car since it was puchased new in '89. Not the sender, we tried. But it does respond when the sender lead is grounded, as if there is high resistance in the gauge or wiring.
Many of the problem circuits appear to share some common circuits. I have looked through miles of wire on top of the motor, under the dash, etc. I got the wiring diagrams off of Alldata.
Help! please!
Thanks.
