RatInDaHat
Everything posted by RatInDaHat
Ok, so i have a quick question from any of you '74 1400 owners. Should the vacuum advance hose be running from the manifold or the carb? That's all i need to know. Thanks, -Dusty-
Weber on a '74 1400
RatInDaHat replied to RatInDaHat's topic in Historic Subaru Forum: 50's thru 70's
ok that is pretty cool. -
Weber on a '74 1400
anyone have a working email for them? Oh, and why do you recommend the manual choke? -
Weber on a '74 1400
What's the best way to go to make sure it is jetted correctly? I really think i am going ot go this route cause i am tired of the hitachi's flakiness. -Dusty- -
Weber on a '74 1400
Or is there a way to fit a SPFI system on the 1400? thanks, -
So.. Anyone here done it? After all of my recent bs, i'm really considering it if i know it can work. Thanks, -Dusty-
Always another issue with me.
guess that would have been good info. it is a 74 gl, with the 1400 and hitachi carb. Weather is down around freezing, or within 10 degress either way. I'm also a mile up in altitude. It does ok when it is choked.. It starts to stumble and miss when it warms up and fails to idle once it is warm. It doesn't even try, it just dies. -Dusty- -
Ok, so here is the new one. Car runs fine and idles when it is cold and the choke is closed. Once it warms up it starts to have dead spots, and has a hard time idling. I know that the choke is opening, but i'm wondering if i am running too rich/lean. Any input?
Speedometer issues
What are these cables lubed with? graphite? -
So.. Any reason for my speedometer to suddenly start reading well over actual speed? I'm talking like reading 60. but only going 40 type of error. My car is a '74 subaru GL (1400) Thanks,
I replaced all of my vacuum lines already. I'm picked up a subaru engine gasket set foe the motor, so i will be replacing some gaskets. Valve covers, oilpan, possible intake. I'm curious if i have a leak there. I don't know if my idle air screw is set anywhere near where it should be. If i can get it idling i'll play with it some.
requested pics of my 74 gl
Adjustment would be a real pain, but they look hot. There are times i will sacrifice functionality for looks. -Dusty- -
Sweet. when i have the cash and time i will give them a call. Thanks.
