About 94Loyale
- Birthday 06/17/1986
Contact Methods
AIM
MPower525i
Website URL
http://www.facebook.com/#!/bret.reifsnyder
Gender
Male
Location
Orwigsburg,Pennsylvania
Interests
Anything with a motor :-)
Occupation
Subaru Technician
Biography
Technician at Deer Lake Auto Sales. I love subaru's :-) And I live for old Fords and Merc's. Also a factory trained BMW technician, and factory trained by Triumph motorcycles.
Vehicles
'99 Outback, '87 Brat
Recent Profile Visitors
94Loyale's Achievements
Subaru Fanatic! (6/11)
10
What Bridgestone's are you running? The Grids and Potenzas are absolutely terrible for scalloping. I would put them right up there with Fuzions unfortunately. I would say it's more than likely the tires, or air pressures. I'm sure some people may beg to differ, but directional tires do not cooperate on subaru's. The only set I have not seen wear funny was my own Goodyear Eagle GTHR's. Otherwise, almost every set of directional's that comes through the shop wear's stupid. I've had much better luck, and terrific wear out of real cheap tires like Ironman, Starfire, and Hercules. For so much less money, they are quiet, perform very well for a daily driver, even in weather, and wear good their whole lifespan. Just my 2 cents
With some rotors you need to cut down that lip on the back of the rotor, I always cut it down flush with the rotor surface. The other problem is the backing plate sometimes gets bent out of shape on the bottom. If you take it back apart you will see where it was rubbing. With the plate, just take a good punch and knock it back where it should be. Also, on some of the later 90's, if the backing plate is bent out it will cause the ebrake cable to come in contact with the abs counter ring. This is also fixed by hammering the backing plate back where it should be.
A WRX exhaust takes a little modification to fit onto anything else. I just modified one to fit on a '02 Impreza TS. It really did not add any noticable tone to it. That's with everything stock in front of the midpipe. The only problems are, the WRX midpipe is too short and needs to be lengthened about 3.5in, and the flange in the front needs to be turned to fit on the cat pipe. (If you hold it up, the flanges are opposite of each other. But it's no problem at all once you cut that part off to lengthen it.
#1 misfire
94Loyale replied to jseabolt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Any oil in the plug wells? Bad plug well seals (extremely common) will make a good misfire when oil leaks in there. Otherwise, I would probably change the plugs. Coil packs are not the common of a failure. When I do see them fail, they fail good and crack on the outside, then you can really see arcing.
