Everything posted by lostinthe202
I had this problem in my '96 Outback. When I brought it to the forum it was suggested by a few that it's the crank sensor, they're prone to cracking and after a "hot soak" the crack can expand and the car won't start. The problem was intermittent and while I did change the crank sensor and the problem did stop happening, I never did know for sure if that was indeed the culprit.
I'm going to pulling a trans from an RX this weekend from a fella that's parting one out and I want to maximize efficiency. I'll be getting the trans, the drive shaft, and the rear diff. I don't have a manual for this car so I can't look up the procedures for the rear axle removal. What size is the rear axle nut? What's the easiest way to remove the axles? Anything else that will help get this done quickly? Thanks!! Will-
So I searched on this and got some conflicting information. I've got a '00 SOHC that I'll be doing a nose job on and I would like to clear this up before I order parts. Looking at the front of the SOHC, It seems like it's possible, but I"m not sure and I don't have the 2.2 apart yet. I've read that the "old style" tensioner is a better design the the "new style", the old style being on ej22 of pre non-interference design. Some say you undo the bracket holding the old one and bolt the whole works on a newer engine. Some say this doesn't work because there is no place in the case casting for the bolts. But none of these threads identify which engines are being talked about. So maybe some clarification from those that know? So the three possibilities that this swap might be applied to are: phase II EJ22 DOHC EJ25 SOHC EJ25 (this doesn't include the 6 because they use a chain correct?) Thanks!! Will-
Sounds under engineered to me. To Subeast-EA81 I assume you're on the east coast someplace, if you happen to be near the washington dc area, there is a red DL hatch at a wrecking yard I know of. PM me if you want details Looks like a fun project! Will-
I was into 70's japanese bikes in my post teen years and those things were held together with phillips head fasteners. I really want to track down the sadistic japanese engineer that thought using phillips would be a good idea and kick him in the nuts. anyway, it did make me the cold chisel expert I am today, then I found the impact screwdrivers that you hit with a hammer like GD mentioned. Those things are great because you can somewhat control the force you exert on the fastener. The battery impact ones I used have no torque control and tend to snap heads off if you're not careful, go ahead ask me how I know
Lifted XT6 with air suspension
lostinthe202 replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not bad for a 6 -
So those Forester wheels are 16" right? How's your speedo? Also, what kind of mileage did you get? Looks awesome! Will- -
Wow, only one response on this post? So how is it holding up?
