About brokebill
- Birthday 06/19/1969
Location
gatlinburg
Vehicles
86GLwagon,5spd,carb,2WD
brokebill's Achievements
USMB is life! (4/11)
10
hot sunny weather=hard starting again
brokebill replied to brokebill's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks. did the same thing last year till the weather cooled down. wonder why it only does it in hot weather? thanks, Bill -
clutch cable broke again
brokebill replied to erik litchy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i've changed 3 in about 4 years on mine. all after market. good luck Bill -
brokebill posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
late fall, winter, early spring started lke a champ.choke seemed to work fine. fired right up whether first thing in the morning or at any time in the day after being cut off for any length of time. seems 70 degrees plus outside and it starts being a pita to start again. 86 gl 2wd 5spd, feedback hitachi. choke related? thanks, Bill -
i cant seem to find replacement rear coil springs for my 86 GL 2wd wagon. old posts seem to steer towards using front springs off an 86-89 accord. does anyone know the factory specs for my spring so i can match it up at Moog? thanks, Bill
Tinting tail lights?
brokebill replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
years and years ago, i found a spray can tint. i don't remember who made it , but it may be an option if they still make it. good luck, Bill -
blower motor quit working.(coldest spell of the year) tested the wire at the blower motor for power. it had power. ran power straight to the fan just to be sure and still nothing. figured i'd have to get a new one so just for the sake of curiosit i'd open it up and have a look. looked a whole lot like a power window motor i patched in my Ford. same problem to. one of the spring-loaded wired contacts had came lose and half of one of the springs was gone. a dab of super glue to reattach the contact to the wire , a thick ink pen spring, and now i have heat again. (my wife was wonderful in helping put it back together since it takes 4 hands to keep all those little parts together during reassembly) wired it up backwards the first time so pulled it back off and we pulled it apart and fixed it right. i will get one my next trip to pullapart but it will do for now. also, isn't the blower motor out of a lot of mazdas interchangeable into my subaru? thanks, Bill
i love the site, unlimited info, a lot of people that know what they're talking about. but, i hate threads that have no ending. i know the main thing is a solution to whatever problem the author my have had, but it would be good to know if and how a problem was fixed. there are relative old threads to just about everything but most have no indication of an outcome. fixed, still broke,set on fire and pushed over a hill, something. not complaining, just hate loose ends and unfinished stories. thanks, Bill
leaky valve covers. checked the bolts and 1 was freespinning. i think i can get to it with a tap. what are the bolt and tap sizes i need for this? thanks, Bill
EA82 Crank Pulley removal help
brokebill replied to cmiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i love that easy access. been off a year and belts/pulleys aint even dirty. good luck, Bill -
i've been to countless junkyards but i havent been to a pull a part yet. do you just pay an admission, find out where your particular car is and then just have at it? also, i saw something about no jacks so how am i supposed to remove brake calipers, shocks etc. ? what cars and years are interchangeable (mostly suspension, brake , axles) with my 86 GL 2wd, 5 spd, hitachi carbed, wagon? thanks, Bill
my oldest son has a 93 and 95 honda civic. just wondering if anybody knows of any good honda forums. thanks, Bill
not to jump to conclusions with a minimum of details, but, kinda sounds like the so very common broken timing belt. (thats the way i've had em go out before, sudden and without warning) good luck, Bill
thats what i kept seeing too and then wondered why after cutting off the key the only code it would flash was the model designation code. i believe it was GD who correcty informed me that the engine must remain running with the ecs light still on to retrieve the code and that it cleared when the engine was switched off. as far as the test connectors and all that to clear the codes, it must be a broad statement that covers various make and models, but did not apply to my carbed 86 GL wagon. the engine has to be running with the ecs light still on. the ecs dash light does not flash the codes. remove the panel directly below the steering column and you will find a small box with flashing red light. i have not had to connect or disconnect anything to get and clear my codes. hook things back up the way you found them first, and once you have found and read the led light under the dash, you'll be suprised how simple it is. thanks Bill
i had to change the hose for the pcv valve on mine. i tried seafoaming it and it opened it up a little but not enough. also the first time i changed the hose it was a little too big and didnt seal well and my problems continued until i put on a proper sealing hose. once you get it to stop blowing oil, your carb will probably need a real good cleaning to function right again. mine did. good luck, Bill
you ever figure it out? on my 86 GL, when the ecs light comes on : 1. i leave the motor running with the light still on(once the key is turned off the code is cleared) 2. with the motor running and ecs light on just remove the screws holding on the cover below the steering wheel.(i can just emove a couple and kinda pull down on it a little, just enough to see the flashing O2 light) 3. take note of what it flashes and thats it. what kept messing me up was the thought that the trouble codes would be stored after the key was turned off. they are not. also on mine, there was no need to plug or unplug any test connectors before reading the O2 light. just leave it running(when the ecs light comes on) pull down the cover and read the codes. ps: my ecs light always comes on after a few minutes of driving due to the speedometer being unhooked. it gives me a speed sensor code. good luck, Bill
