Mr. Brat
Everything posted by Mr. Brat
  1. Is there some sort of an itinerary of when this shin dig will start?
  2. It's lookin like I will be leaving about that same time Friday night.
  3. I am not sure when I will be leaving, if anything it will be Friday afternoon/evening or early Saturday am.
  4. Any one headed over from the south puget sound area either friday or saturday?
  5. The shocks are good (about 7 months old or so). Full rebound and extend smooth.
  6. I am trying to keep the rear end in the air. With the brat empty (canopy, rack and tire), when I take off from a stop it feels like the bumper is dragging the ground.
  7. I think I am going to get another torsion tube and try it at the lowest setting with the coild overs on the lowest setting (wagon coil overs). If that doesn't work I will have to try something else. Maybe reclocking the torsion bars, or just maybe putting a longer bolt in the adjustment bar. I dont really want to go with the airbag setup. Still thinking........
  8. So I installed the coil overs on with the torsion bar turned up. Way to stiff (like what was said and I thought it would be). Tried to turn down the adjustment of the torsion bar and broke the bolt. So I removed the torsion bar from the tube. Reasembled everything, turned the coil overs to the stiffest setting and went for a drive. Bottoms out and doesnt flex to save its life. So this part was a fail! Gonna try something differant.
  9. Hey guys, what have you done if you broke the adjustment bolt for the torsion tube. I put the EA82 coil overs one and was trying to releave it for the softer suspension. I am thinking about the bar that the bolt goes to just remove it. I think this will work, what do you think?
  10. Built the brackets tonight. I made mine a little differant than was shown. I am not using any washers. I drilled the holes for the coil overs bigger than the bolts I used and then welded the nuts to the front of the plate. Thus using less "washers". This was still not enough spacing, so I drilled the center of the same size nuts out and used those as spacers. This worked perfectly, have about a 1/4 inch between the coil and the inner fender. More to post later.
  11. Thanks, I figure about 300-400 lbs for the canopy, basket and spare swamper. If it was to bouncy I was going to use the torsion tube as my adjustment. I will post what I come up with. Now looking at the other post that were on here. I may have a broken torsion tube. The drivers side of the brat sits down 3/4-1 inch lower than the passenger side. There is not a load on either side... already checked.
  12. I have searched and found one post on this, which the question was never answered. I have the same problem evtte had. The rancho shocks are to soft. Now before I get the "put the air shocks on" story. I have a 4 inch lift on my brat, I also have a canopy with a roof basket and full size spare. So I already have alot of weigh in the rear. When I take off from a stoplight, in the mirrors all I see is pavement. I seen the GD has put the EA82 rear coils on his EA81, I would like to know if there is an easy way this could be done. zzz
  13. 85 Brat EA-EJ adaptor plate Flywheel redrilled Havent had a single problem one, Scott even called me to varify what I wanted. TOP NOTCH!!!!!!!!!!!
  14. I have done that trail also in a roo. been a couple years. Probably alot worse by now.
  15. So I have a tow bar for flat towing my brat. I am going to wire it into the original harness for the tail, brake and turn signals. Has anyone done this yet?
  16. Sounds like the cops were diggin the "BRATS", every one slipped by without a ticket. Sorry ZAP, cant say the some for you. Should have brought the brat. I know I cant wait for the next meet!
  17. Hey I have a weber 32/36 with manual choke if you are interested.
  18. No speeding tickets for me this weekend! Barely scaled by that one... 61 in a 45!
  19. :grin:Thats mine, I drive threw Yelm to go to work.
  20. Took 3rd place in tuff truck race in Rainier WA. this last weekend. Now I need a new p/s pump.
