ronwomack
Everything posted by ronwomack
i had just settled in for a long day of chasing electrical problems again today. i have had several electric problems which i was able to cure with a new ecu. my cruise control was still not working and i geared up for a long day with the multi meter. after reading a few posts on this site i decided to start with the clutch switch. on visual inspection i was able to see that the rubber seat in the clutch pedal was missing which allowed the switch to go right through the hole where it used to be, i filled the hole and presto, i have cruise! now i don't have anything to do with the rest of my day ha ha. i can't begin to say what a great site this is, it has helped me immensely. thanks ron womack
hey everyone. just to let you know. i replaced the ecu and my codes have disappeared. i took her for a short drive and checked for stored codes and found none. i can't tell you how happy i was to find a recent addition to the new salvage yard with most of the items that i have needed except for a driver side turn signal but oh well. thank you for all of your help. i will recheck for codes in a week or so and update to let you know how it worked out. also, rear wheel bearing swap went well thanks to a lot of info that i found on this site. i can't thank you all enough for all of your help and input ron womack
hey there legacy777. i did try resetting by connecting both connectors. i haven't messed with it for a couple of days. it is still running with cel codes for the idle switch, speed sensor, and cannister purge solenoid. the cel comes on after driving for about 2 or 3 miles. i haven't looked for a ecu yet as the wheel bearings need changing and are a more pressing issue. hope to get those done this weekend. thanks for the input i appreciate all of the help you guys have offered up. thanks ron womack
i haven't ruled out the possibility of a bad ground yet. an ecu is a pretty expensive part so i would like to rule out any other possible causes. if i were to buy a salvage ecu how exact do i have to be? my local salvage yard has several susbarus around the same vintage however all of them are auto trans. i still have the speedo from the auto trans that i originally swapped. any ideas what years are compatible? my chilton's would leave me to believe that 90 to 94 have the same wiring connections for the 2.2 l engine. thanks again for all of the help. sorry for any complaining. it actually turned out to be an interesting challenge that i'm sure will continue. ron womack
thank you cougar. the problem was the fusible link #2. i did a visual on it and it appeared to be good. however when i removed the relay i was then able to see that it was blown. a lot of time wasted because i didn't look close enough in the beginning. as for the other problems i think that i am down to code 33 and 35 still. don't think that i will worry too much about them for now. thank you guys for all of your help and patience. couldn't have done it without you. ron womack
i found it. that made for a long day. i think that i will stop tinkering. i believe that most of my error codes are erroneous since i know that the components are functioning. perhaps the problem lies with my inexperience and not the car. i get about 21 mpg in the dead of winter on mostly short trips and she runs as smooth as can be. time to stop messin with it. thanks so much for all of your help ron: womack
ok cougar here is the latest. further testing has showed the ign relay to be good. when energized i have continuity between the proper terminals. i still do not have power to pins a2 and a13 on the ecu. i checked power to the two yellow wires that supply power power to the ign relay (not the light green wire that energizes the relay) and have found them to be dead. they are supplied by a fusible link i believe the number is sbf2 or s8f2 30 amp (my eyes arent as good as they used to be) any idea where this is located? thanks ron womack
it just keeps getting better! just for fun i thought that i would replace the cpc solenoid again (i grabbed a few from the salvage yard) the new one ohms well and audibly energized. while checking for voltage from the cpc i accidently shorted out my lead on the manifold, the engine instantly died and will not start. now i can't even get it out of my shop to work on something that isn't frustrating. i'm very near hauling it off for scrap. thanks for all of the help that you guys have offered ron womack
ok guys this is getting frustrating. last night i reinstalled the original instrument cluster so now my vss and ecu should be the corrrect match. while i had the car in the shop i replaced the air filter, to do this i disconnected the air flow sensor then came up with an additional code (#49 for the air flow sensor.) i disconnected the battery and let it sit overnight only to find that all three codes (33, 35, 49) are all still there. i do not think that all of these parts are bad expecially the air flow sensor since the code was never there before. is it possible that i am doing something wrong in the code reset process? i am getting tired of fighting this. thanks again for your help ron womack
thanks for all of lthe fantastic info. the cannister solenoid vavle that i used was from a salvage. i did however check it with an ohm meter and energize it to ensure operation before i installed it. as for speedo. i saved the old instrument cluster and will replace the speedo unit to see if this corrects the problem. thanks again for all of the info. i will post the results when i make the change. thanks ron womack
the speedometer is working, i have replaced the cannister purge solenoid valve. this is why i am looking towards the ecu or its connections as a possible cause. the speedo that i used to replace the one that was damaged in it's vandalism is out of a auto trans. my vehicle is a 5 speed. is it possible that they have a different signal? thanks ron womack
i own a 91 legacy wagon. the vehicle was vandalized is 2001 and has sat ever since. i have recently replaced all of the glass instruments and broken hardware. i am getting a code 33 and 35. i have reset the ecm and replaced the instrument gauge cluster (code 33, vehicle speed sensor) and the canister purge solenoid valve (code 35.) after resetting the computer the codes return. i suspect bad wiring or connections. can anyone tell me where the ecm is located. i would like to check my connection there and possible pinout voltage. any other help would be appreciated> thanks ron womack
