ok so I 've got a 98 legacy 2.2L going into a 92 loyale. It cranks, the fuel pump primes, won't start, (haven't checked spark yet) here is the thing I'm stuck on there is a wire shown on the front page of the legacy wiring diagram that starts at (ST ig sw) runs to starter interlock, N. Pos. S/W, ecu pins 82 ,75, 17, and 18. then it finally goes through engine wiring harness to an indirect ground (whatever that means.) so I didn't like the idea of having starter circuit voltage going through the computer. I put in a fuse and its constantly blowing during cranking. I wired it into one of the two ignition sw wires that is hot only during cranking (st position) My first thought is why is a starter voltage carying wire running through the computer and straight to ground with no load ( explains blown fuses ). Any ideas I'm completely stumped.
thanks
