bobaru
Everything posted by bobaru
my trans is not on this chart http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart Its a ty752vabca the car is a 96OBW 2.2 I found some trany's in local yards none of which match. I know I need a 4:11, Its the 5th gear where im lost I found a ty752vacba and a ty752vacca plus others thank you
Ill be putting a new clutch in my 96 single port outback and while the motor ss out I my as do it all 170,000 miles. I ordered a timing belt kit water pump& seals , clutch kit. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220471949854&viewitem=&sspagename=STRK%3AMEWNX%3AIT http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390063920974&viewitem=&sspagename=STRK%3AMEWAX%3AIT All i can find is complete gasket sets $150.00 plus with a bunch of parts I wont be needing so Im thinking it would be cheaper just buying the parts I need. heres my list so far 2 head gaskets 2 intake manifold 2 exhaust gaskets 2 valve cover gaskets Is there any thing Im missing I will also be buying the oil seperator plate thank you
dude Is in Isreal
Skid plate saves the day (not how you think)
bobaru replied to Gloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
talk about luck ........did you at least buy a lottery ticket -
the headlamps I got look the same to the naked eye.... to the measuring tape there about 7/8" differ at the grill in the deepness thicker........ Driver side fits with body lines on both hood & bumper corner is tight......... Passenger side is thinner in depth at the grillside hoodline and bumerline does not lineup..... corner is cocked Again the the car has not been wrecked .....I could shim to fit and it will but grill wont fit Ive looked at ebay 95 96 97 are one piece lights ...........97 98 99 are two piece so im back to is outback different from legacy
coolant level
bobaru replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
drip drip drip drip drip drip drip sloooooow fill god that took for ever -
coolant level
Nipper I agree 100% with your instrutions but shouldnt the cap pull coolant out of tank the last void of air I know it does this with water on this car cause I drained old rinsed with clean water twice both times sucked the air void out of rad.. now the coolant no sucky the tank to fill rad meantime I'll fill when it cool thank you -
96 2.2 outback 5sp .........my coolant seams low to me infact when I look In I can see what looks like the the ATF cooling coil.... 2 inches or more... I have no problems with temp at this time. is this the normal level? .......... Only reason im asking is bought it yesterday fluid changes today and I had a hell of a time getting the the coolant in. The cap I bought is a napa 13lbs new today I looked at my 93 s10 4.3 and my 93 cummins 5.9 both radiators are full to the top of the tank. just seams odd coolant res. is full and again I have no problems with over or under heating at this time
