Palouse Rider
About Palouse Rider
- Birthday 08/04/1952
Contact Methods
Website URL
http://
Location
Spokane WA
Interests
sailing, motorcycling
Occupation
service tech
Biography
it's just little ole me
Palouse Rider's Achievements
Member (2/11)
10
My friend has a '98 that she says made a knocking sound, died, and now won't turn over. I put a fully charged battery in it. When I turn the key I can hear a relay click under the dash some where, but NOT the starter solinoid. Is there a start relay somewhere I need to check out? Does anyone have a schematic that would be helpful? The car also returned one PO335 which I reset, but still no joy. Any suggestions welcomed. Thanks in advance!
OK, This has only happened a couple of times and not for a long while, but I am getting ready to sell the car and don't want the new owner to have any nasty surprises. (I like the person) At times it had been very hard to shift from neutral to first, then also up through the gears. Almost like the clucth wasn't engaging, but it was. It's a very young clutch and TOB. And has a new slave cylinder. Now here is the kicker. The last time it did this to me, when I finally forced the thing into gear and let out the clutch, it made VERY expensive banging and grinding noises. I immeadiatly put the cluch in and coasted to a stop. Trying to find my cell phone and credit card and to call AAA. I knew something must have broken. I decided to try it once to see what would happen and it shifted and drove just fine. In fact, it's been 6 or more months with out any shifting problems at all! Any ideas?
Yea, it's a 1998. The noise appeared about 20k after I got the car. The car now has 106k. It is only on the left. I think the strut bushing theory is the best one. The dealer wanted to do both, because they like to run up the bill I think. I'd like to try and fix this myself, but struts scar me. -Cheers!
This is likely to get some mixed responses
Palouse Rider replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My '66 AH Sprite had dual SU's, but now it has a Weber! Runs great. My buddy had a Honda CBX, inline 6 cylinder with , yes, 6 carbs....ouch! My BMW F650 single has two carbs!!!! Cheers! -
THAWA, Thanks for the help. It went well, just as you described. BTW, I don't think there is a Haynes manual available for the Forester yet. Ed, I had broken two 19mm sockets trying to loosen the strut nuts:confused:, with a breaker bar and a piece of pipe, but thankfully it was not necessary to loosen them.
After looking at several circuits for automotive digital clocks, I believe the resistor I replaced was not to drop 12v to 5v but to drive a transistor which enables the display. Indeed the clock does have a voltage regulator. Remember we are not dealing with alot of power draw here....it's just a digital clock. I suggest you take your clock apart and inspect it for the missing resistor. Mine was (not)loctated beside the upper left hand side of the display. One more thing, the display lens will look burnt on the lower left. That happens during manufacture when they fuse the thing together. -Cheers
