1997reduxe
Everything posted by 1997reduxe
The term "JDM" means Japanese Domestic Motor, right? This is merely a term for a whole slew of used motors coming from Japan, not a particular brand name... So there are a whole lot of these companies out there reselling engines, probably a lot of bad ones, correct? These would be different than Jasper motors though. Samneric, here's a shop I found here in Houston, may be less shipping for you, can't tell: http://www.usedjapanmotors.com/ Dan
Hmm, good prices for good suggestions. Still, Michelin HydroEdge are the best tires ever made. And good in snow too. 90,000 wear promised. And I took their X-Ones, which were my previous "best tires ever made," (they used to be 80,000 wear,) to probably 120000+ miles. Yes, metal was showing through, but they still ran and ran, and ran.
And just as a point of interest in my first research I did today looking around at the H6 engines, I notice that they went to a timing chain vs belt? After all those years of belt experience? That's a pretty amazing change. But then I'm obviously way behind the times. Gonna have to look into that. Dan
yeah I just thought I'd throw that out there about trans anti-maintenance. To tell the truth after I said it I thought how that kind of philosophy probably was bigger in the old days when cars, particularly American ones, often didn't make it to, or much more than 100k. (The 80s, K-cars etc.) (Tho I did think that I heard it on this forum once or twice.) But I have to say in my experience with Legacys, if you buy one or are looking to, and they possibly didn't change the fluid recently, the fluid is clear or pink, not burnt, and no major leaks, then you are probably very good for a long long time. My 97 I think I got the flush when I bought it, it eventually had a small leak, and when it would start slipping I'd fill it a little, and it went like that till I sold it at like 325k, which again, was a mistake. And BTW, SUBARU3, sent you a PM about a good Texan source for Sube work, though down here towards Houston, FYI.
new tires
1997reduxe replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You are out in the middle of nowhere. I'll bet it's beautiful though. Always wanted to go to Montana. They have those KM2s if that's what you're going with at Tirerack for 576 bucks plus 90 shipping. I guess the problem for you is going to be finding an aggressive enough pattern for your size tire. Personally I'd try to find something with 4 steel belts, but that may be a fantasy. On tirerack they also have the Duelers and T/A KOs for about 130 each. But they're more on-road than off. If you really wanted to get crazy you could try these, but I don't think they make em small enough, at least with 15 inch wheels, you'd have to go to 16 inch: http://www.quadratec.com/products/92607_10XX_PG.htm (And they're on ebay too) Miata tire calculator just in case you haven't seen: http://www.miata.net/garage/tirecalc.html -
and if you do decide to check out the alternator, you can take it to autozone, (don't know about o'reilly or other parts places) and they'll test it for free. Has to be off the car though. It may not test bad since you said you only had problem when hot. In case you do have to replace it: http://www.ultimatesubaru.org/forum/showthread.php?t=133324
Yeah, believe me, living here in Houston with all the giant trucks etc you get a real taste of the American need to continue rocking on with gas guzzling. I can't understand it, though it seems to just be a pride thing, like no disaster or possible eco-crash will deter us from 12 miles per gallon. I did have a friend who drove every day 50 miles to work downtown and in his Prius used about one gallon each way. Now that is smart. Thanks again John. Good public transit article: http://usnews.msnbc.msn.com/_news/2012/06/04/12051097-public-transit-ridership-rising-sharply-advocacy-group-reports?lite
And I forgot to ask, when you're doing the drain and fill you're dropping the pan and cleaning off residue (and is there a screen to clean?) Or just draining and filling? I know I've heard some people who are of the impression that if a trans has like over 200k on it and it's running good, don't disturb it at all, other than adding fluid if necessary. Dan
yeah, where's it leaking the oil? can yu see any drips or pools if you park it on clean pavement? (hard to find) you're sure it's burning it out the tailpipe? I have a 95 that just needed a cam seal along with timing belt kit relacement etc. It also has some small leak still, trying to trace that one down, but when it the cam seal went it was like it was burning oil, but it was burning off the exhaust. prob about how much you're talking too. i just didn't drive it till i got it fixed. now very happy.
Yeah well what you meant was that you found a listing of that year on a site, and they said the car would be offered either as a 2wd or 4wd, right? Or you actually were told it is in 2wd? I would really try also to get any info you could get from the owner, maint. records, that kind of thing. It can reveal a lot about what you need to concern yourself with immediately as far as maint. needs. Or find out who did the work on the car, they would know its history. And when you choose a mechanic be sure to get your own copy of haynes or chilton's manual (along with this site) and evaluate the maint requirements yourself against what they say to get done. I used to have a mechanic do what he thought was the proper maint, but realized after a while he wasn't necessarily aware of all the proper things Suby... At 90,000 miles, that car would likely not only get you through school, but your first job as well. My old gf had a 95 with about 90k on it when I met her, I learned all my first Suby ignorance/chops from that car, and had she and her family had listened to me after we broke up (regarding the car) it would still be running, 12 years later. But it went to 300k. Where in PA, btw? You may get some good recommendations for shops on here. I used to live in Philly/Pottstown/Berks area. I know one great guy there.
Hey, trying to help this guy whose sube engine blew in Huntsville.
Know anybody who can rebuild a 2.5 in that area?
Here's the thread:
Hey, just trying to help this guy whose sube engine blew in huntsville. thought maybe you knew a good sube mechanic in that region? Here's the post we're writing on:
