skibumm
Everything posted by skibumm
I've scheduled an appointment for a local muffler shop to weld a new pipe and flange to the cat pipe, Im not real confident that the new weld will hold up though. the metal on the cat seems quite thin. I have had similar problems with my 97 outback and the weld failed in about 2 months. This seems to be a week spot in the outback exhausts. I will order the OBX headers if it fails again..........
Has anyone any experience with the OBX headers that are sold on ebay? I don't live in an area that has emissions testing so that is not a problem. The three inch long pipe with the rusted away exhaust flange has broken off the the back side of the center cat. If I cant get this welded back together the headers look like a cheaper option to factory cat pipes. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=151063791278&ssPageName=ADME:B:WNARL:US:1123
Is there an axle washer that goes behind the axle nut? My Left front wheel was feeling loose and figured it was a bad wheel bearing. So last week I pulled the hub and took the knukle off the car, got new SKF bearing/seals and took them down to Wheeling Spring shop to have the old one pressed out and the new one put on. I put the knuckle back on the car and installed a new lower ball joint also last Saturday, I have driven the car about 75 miles. Tonight I noticed a clunk when turning at low speed. I check the axle nut that it was still tight and then noticed the wheel bearing felt bad again. I ask about the washer, because the axle nut seems to go on past the notch in the axle that you cant lock it on with a punch. The other thing going though my mind is the shop didnt change the old race and just put the new bearings on the hub......
I 2nd the motion on Hakkas, over priced, they ware excellent and have outstanding traction in snow, but after about 2 seasons the belts start to break. Go with the General Altimax Arctic, these are made in Germany using the Swedish Gislaved tire mold. they are sensibly priced and can be studded and ware excellent.
Whats broke on your subaru lately.
skibumm replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Got in my 01 vdc obw the other night to come home and had no low beam lights, thank god Walmart stays open 24 hrs and was only 3 miles away. fog lights don't shine very far and I hate blinding someone with hi beams. -
Get a 2.2 from a 95 and the y pipe, changes are after your beer buddies do the work, you'll need to rebuild it again, don't forget cam seals, oil pump seals, water pump, separator plate and new timing belt. I have seen several outbacks for sale that still have Head gasket leaks even after they were fixed by a local mechanic. 2.2s are $200-400 and almost bullet proof. I just checked car-parts.com and found a local 95 2.2 w/93K and warranty for $325. Bet there there are 2.2s in your area for sale that are similar.
Dextron VI ?
skibumm replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Do you use the regular or synthetic Dextron VI, I intend to use Valvoline full Synthetic Dex VI. at the next atf change. -
I have a 2001 vdc, 125,000 miles, great car, but lookout for the serpentine belt pulley bearings, they go bad quite often. I took mine on a 4200 mile ski trip this spring to Colorado, the car was assume in a blizzard through Vail Pass on I-70, Couldn't see 20 feet in front of me at times, forecast was for 31" of snow in Vail and there was every bit of 15" of snow on the I-70 pass. The week before there was a 47 car pile up in the pass. In Colorado they don't use salt on the roads, so the packed snow turns to ice, good thing they make the Semis use chains. With the vdc and a good set of all season tires, the car never slipped at all. Only problem was avoiding 2 wheel drive cars that had stopped on or along the road.
I hadnt drove my H6 for about 3-4 weeks, got in it the other day and both the CEL and VDC Off light stayed on, filled it up with a new tank of gas plus I pulled the battery ground, lights are still on. Went to Autozone today to check the CEL and found it to the the Oxygen sensor on the #2 bank. They wanted $161 for the sensor, ouch!. Does any one know of a good place to buy one? Also which side of the car is the #2 bank on? left or right side looking at the car from behind. Thanks Brad
Is there an internal filter that needs changed in the 01 Outbacks?. I changed the spin on filter today with a Napa Gold oil filter, what a pita, probably has never been changed before. Anyhow I didn't see any other filters at http://www.1stsubaruparts.com. I'm going to be doing 3 changes to get most of the old fluid out, also planning on adding synthetic ATF on the last fill.
Since there were no dealers open till Monday, I bought the Autozone thermostat last night on the way home, but they didn't have the gasket, so went to Napa this morning and bought the gasket and a Napa thermostat. However the Napa thermostat didn't have the vent hole like the one that was on the car and the Autozone one did. I'm going to change the antifreeze, so will get the Subaru stuff then.
I did stop and check a few times coming home that there was antifreeze in the overflow tank and that there were no leaks dripping from under the car. At times it acted like the thermostat wasn't working right as the temp would spike upward and then drop back, even underload..... I will look things over better tomorrow, skied 4 days, I'm beat, just glad it made it home without overheating.....
I drove to Snowshoe WV this week with my H6 VDC OBW, on the way down I79 my idler pulley let go and broke the alt. belt., fortunately I was only a couple miles from the Subaru dealer in Bridgeport WV. Cost me $226.00 and they didn't even have a Subaru belt, had to get one from Napa. Anyhow, on my way back from Snowshoe the temp needle started creeping up to over 2/3 of way on the gauge, (half way between the 2 upper white marks on the gauge). It would only do it on a hill pull and then level back down to half way on an incline. What are my chances this is a water pump going bad?, I'm hoping its a thermostat or radiator needing a good flush and cleaning. The H6 looks like a bear to replace a water pump on.
